G29 crash my delta !!!
hello, i have à problem with my delta and Repetier-Firmware 0.92.3.
Here is my config :
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 199.822
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_PERMANENT 0
// ##                           Movement settings                                          ##
// Delta settings
#define DELTA_DIAGONAL_ROD 293.25 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_MAX_RADIUS 100
#define ROD_RADIUS 179.66
#define PRINTER_RADIUS 179.66
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_FLOOR_SAFETY_MARGIN_MM 15
//#define SOFTWARE_LEVELING
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 300
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 200
#define HOMING_FEEDRATE_X 50
#define HOMING_FEEDRATE_Y 50
#define HOMING_FEEDRATE_Z 50
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 0
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 10000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 10000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 10000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 10000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 10000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 10000
#define MAX_JERK 50
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define X2_ENABLE_PIN E1_ENABLE_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_ENABLE_PIN E1_ENABLE_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_ENABLE_PIN E1_ENABLE_PIN
#define USE_ADVANCE 0
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 0
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET -18
#define Z_PROBE_SPEED 50
#define Z_PROBE_XY_SPEED 250
#define Z_PROBE_SWITCHING_DISTANCE 2
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 0.4
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 82
#define Z_PROBE_X2 86.6
#define Z_PROBE_Y2 -32
#define Z_PROBE_X3 -86.6
#define Z_PROBE_Y3 -32
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
The problem is this, if launch a G32 all are correct probing bed in the 3 point defined in my setting. If i launch G29 head go down 10mm bed center and move to my defined point x0 y80 and crash head in bed ! Why i have missed ?
the probe is : 0.4mm top of nozzle
diameter : 200mm
height : 200mm
help my please :-(
  • Your description is not clear enough to see any error. In general G32 and G29 use the same routine for measuring z height, so if one works the other should work as well and G30 the same. But you should not use G29 if you have G32 which is better.
    The only thing that could be is the for some reason the probe did not trigger during G29 which of course causes the crash or if printer was not homed on G29.
