Cannot run auto leveling then distortion correction
So what’s happening is if I run auto leveling it measures as planned and inserts z height as 284.387, then if I try and run distortion correction it give error of unreachable cycle probing of 4.00056, 5.0458 or something like that. Can’t remember the exact error wording.
Also if I try to run auto leveling a second time it gives the same error message unless I change zheight back to the original 290 before I ran auto leveling the first time.
Test point 30 / 35 means offset must be <= 30 / 35 if extruder 0 has offset 0 / 0. Note that some offsets are in steps not mm.
