Extruder Stepper is not working!
I just built a i3 from kit, MKS Base 1.2, everything working excluded the extruder stepper, I used the local control function "move axis", it is good for X, Y, Z, but the extruder. i tried to connect the extruder to the z-axis, running "move axis", and it's working. i am sure the wiring is correct.
Can i update the firmware to solve the problem? But i have no idea how to backup the existing program.
Please help, thanks in advance.
  • Was the extruder hot? Extruders have some safety functions to block cold extrusion. In 0.92 you can use
    M302 S1
    to allow cold extrusion.
  • Does it mean the heat of the nozzle?
    The nozzle is hot and the PLA is melted. Only the stepper is not moving. The PLA cannot be loaded to the extrusion.
  • Ok, if it is hot it's not the cold extrusion problem. So it could be dry run in host activated or not all eeprom values set correctly (had this my self after a update). Try changing eeprom mode to reinitalize eeprom values in case they are the problem.
  • I'm having the same problem.  Heater seems to be working and monitored in Host, but stepper motor won't work.  I've tried M302 for cold extrusion, no help.  Could this have something to do with the RAMPS calling this E0 but the Host software calling it Extruder 1?
  • No, host numbers extruders from 1 which is more human like but knows to start with 0 for firmware.
    Are you using 0.92, because 0.91 has no cold extrusion.
    Does the motor at least block when doing extrusion so it gets powered?
  • Am having same problem extruder motor will not work. Plugged into z motor - works - changed board same problem no extruder motor using version 1.0.6
  • Reloaded eprom settings - how seems to work - just need a new extruder  -just rammed it into the bed. not very clever
  • Good hint, so SeanT please also check eeprom especialle steps per mm and acceleration for extruder.
  • My input for SeanT and others reading this conversation: My problem with the Extruder not working seemed to trace back to power supply troubles.  After changing out the extruder motor to one that worked, my Z axis began acting up.  Switched Extruder / Heater / Bed power supply to an old monster I had in storage, and all began working.  Trouble is, that power supply outputs about 16V so the steppers are getting very hot.  I plan to buy a 12V switching power supply as a final remedy.
    I also had to check "reverse motor direction" on the Extruder motor in the web site configuration.
    Lastly, the M302 cold extrusion command was helpful in debugging.
    I have the tevo tarantula with the mks base 1.4, and i am having the same problem. Coulld you help me with the eeprom configuration?
    This is a copy of my Repetier file: https://www.dropbox.com/sh/4lhaceodwt2d4rx/AAC7vFkLGhdzIMUTzcyPdVZYa?dl=0
  • edited August 2017
    Hi
    I also have problem with dual extruders. I am using Bondtechs extruder connected to Rapms 1.4. Ext. 1 is connected to E0 and Ext.2 to E1. Heating of both heaters is working aswell as the termistors. I get both extruders up in Repetier Host 2.0.1 but only extruder 1 (E0) is running. I have tested with new stepper driver and also change the Cables between them. Allways Ext(E0) that is working but both extruder steppers is working. All other steppers (X,Y and
    Someone that can help me?
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       generator: http://www.repetier.com/firmware/v092/
       as you expect.
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_PIN
    #define FAN_PIN -1
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 1
    #define XAXIS_STEPS_PER_MM 200
    #define YAXIS_STEPS_PER_MM 200
    #define ZAXIS_STEPS_PER_MM 200
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET -1800
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 460
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 1800
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 460
    #define EXT1_TEMPSENSOR_TYPE 1
    #define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
    #define EXT1_HEATER_PIN HEATER_2_PIN
    #define EXT1_STEP_PIN ORIG_E1_STEP_PIN
    #define EXT1_DIR_PIN ORIG_E1_DIR_PIN
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_HEAT_MANAGER 3
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 14
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define ENDSTOP_PULLUP_X_MIN false
    #define ENDSTOP_PULLUP_Y_MIN false
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR 1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 320
    #define Y_MAX_LENGTH 300
    #define Z_MAX_LENGTH 300
    #define X_MIN_POS 0
    #define Y_MIN_POS 300
    #define Z_MIN_POS 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 2
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 2
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 40
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT SDSS
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 0
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 1
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "COREXY"
    #define UI_PRINTER_COMPANY "GAIN Engineering"
    #define UI_ANIMATION 0
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_HEATED_BED_TEMP_PLA 40
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
    #define UI_SET_PRESET_HEATED_BED_TEMP_ABS 80
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
    #endif
        "editMode": 2,
        "processor": 0,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 200,
        "yStepsPerMM": 200,
        "zStepsPerMM": 200,
        "xInvert": 0,
        "xInvertEnable": 0,
        "eepromMode": 1,
        "yInvert": 0,
        "yInvertEnable": 0,
        "zInvert": 0,
        "zInvertEnable": 0,
        "extruder": [
                "id": 0,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 50,
                "startFeedrate": 20,
                "invert": "1",
                "invertEnable": "0",
                "acceleration": 5000,
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 460,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": -9,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": -1800,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "id": 1,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_2_PIN",
                "heaterPin": "HEATER_2_PIN",
                "maxFeedrate": 50,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetract": 0,
                "stepsPerMM": 460,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "xOffset": 9,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 1800,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 1",
                    "step": "ORIG_E1_STEP_PIN",
                    "dir": "ORIG_E1_DIR_PIN",
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 4,
        "yMinEndstop": 4,
        "zMinEndstop": 4,
        "xMaxEndstop": 0,
        "yMaxEndstop": 0,
        "zMaxEndstop": 0,
        "motherboard": 33,
        "driveSystem": 1,
        "xMaxSpeed": 200,
        "xHomingSpeed": 40,
        "xTravelAcceleration": 1000,
        "xPrintAcceleration": 1000,
        "yMaxSpeed": 200,
        "yHomingSpeed": 40,
        "yTravelAcceleration": 1000,
        "yPrintAcceleration": 1000,
        "zMaxSpeed": 2,
        "zHomingSpeed": 2,
        "zTravelAcceleration": 100,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 300,
        "zMinPos": 0,
        "xLength": 320,
        "yLength": 300,
        "zLength": 300,
        "alwaysCheckEndstops": "0",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "1",
        "yHomeDir": "-1",
        "zHomeDir": "1",
        "xEndstopBack": 1,
        "yEndstopBack": 1,
        "zEndstopBack": 0,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 0,
        "directionDelay": 0,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "0",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "0",
        "hasHeatedBed": "1",
        "enableZProbing": "0",
        "extrudeMaxLength": 160,
        "featureController": 11,
        "uiPrinterName": "COREXY",
        "uiPrinterCompany": "GAIN Engineering",
        "uiPagesDuration": 4000,
        "uiAnimation": "0",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiPresetBedTempPLA": 40,
        "uiPresetBedABS": 80,
        "uiPresetExtruderPLA": 190,
        "uiPresetExtruderABS": 240,
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 14,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 0,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 275,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "0",
        "fanPin": -1,
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbePin": -1,
        "zProbeBedDistance": 10,
        "zProbePullup": "0",
        "zProbeOnHigh": "0",
        "zProbeXOffset": 0,
        "zProbeYOffset": 0,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 2,
        "zProbeXYSpeed": 150,
        "zProbeHeight": 40,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "1",
        "zProbeX1": 20,
        "zProbeY1": 20,
        "zProbeX2": 160,
        "zProbeY2": 20,
        "zProbeX3": 100,
        "zProbeY3": 160,
        "zProbeSwitchingDistance": 1,
        "zProbeRepetitions": 1,
        "sdSupport": "1",
        "sdCardDetectPin": "SDSS",
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": "ORIG_PS_ON_PIN",
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "distortionXMin": 10,
        "distortionXMax": 190,
        "distortionYMin": 10,
        "distortionYMax": 190,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "primaryPort": 0,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
        "manualConfig": "",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 0,
        "zProbeZOffset": 0,
        "uiBedCoating": "1",
        "langEN": "1",
        "langDE": "0",
        "langNL": "0",
        "langPT": "0",
        "langIT": "0",
        "langES": "1",
        "langFI": "0",
        "langSE": "1",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "defaultPrinterMode": 0,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 0,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 5,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "maxHalfstepInterval": 1999,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 2,
        "version": 92.9,
        "primaryPortName": ""
  • If driver is ok it could still be one of the pins on to the driver. First test if mobing extruder 2 enables the motor. Should then block. If not test if orientation is correct and if invert enable signal is wrong in config.
    if it is blocking the next question is if step signal comes through. Not sure how to do best. You would need to remove stepper driver and measure the signals on step pin, ideallywith logic analyser but i guess you have none. A multimeter should also show something different then 0 when you extruder with high speed
    M302 S1
    to allow cold extrusion for testing
    T1
    Then extruder with high speed but only 100. you have configured that long extrude moves will be ignored so do not try lopng moves. Better a script with many smaller moves in relative extrusion mode.
  • Hi
    Tested with a new stepper driver, nothing Changes. If I change to motors from E0 to E1 I can only hear a click in the motors when conecting to E0, E1 is dead.
    Is there any jumper I have missed on the board?
    BR
  • Problem solved.
    It was the Ramps 1.4 that had some errors, Tested with Another board and now E0 and E1 is working.
    Thanks.
    BR
