Connect to PRUSA Mini
Hi guys,
can you confirm that Repetier Server can connect to the PRUSA Mini, as it is running Marlin 2.0, or is thsi unclear?
Thx,
Michael
Thx,
Michael
Maybe just wrong settings, but since it is not 100% Marlin firmware the problem could be there.
Naturally there is no extra info on the display - that is controlled by the firmware and has no status line any more. There is also no progress info when printing over usb. That is a decision of prusa/marlin so nothing we can do about that. But the important fact is that it is printing without any problems from server connected to usb.
If you experience any problems I did not see so far, please provide a log around the problem time and describe what happened.
My setup: Rasperry Pi 4, with Repetier Server Pro 0.93.1 , Prusa mini with FW 4.1.0 final.
The printer is shown as green in repetier. But if I try to do anything (as test change the bed temp) nothing happen on the printer.
What are the correct settings?
Did somebody has a configuration file for me which I can try?
Not sure what I should change that it works for me.
Thank you for support in advantage.
https://www.dropbox.com/s/xlyguc7p6q4nya9/Prusa_Mini.xml?dl=0
Thank you very much.
First print is running
I used a USB A to USB A Cable to connect the Mini to my PI
I have raspberry pi3 and prusa mini with last official firmware.
