STM32 Firmware Flash
I use rumba32 with repertier server and as mk4duo and klipper firmware (in test). I was wondering if there is a way to program the card directly from the repetier server. I for mk4duo generate a .hex file from the arduino compiler 1.8.10. Thank you very much for helping. Lorenzo
I recently discovered that stcubeprogrammer for linux, I have to try to see if it works on raspberry and it could be the solution, it would be very nice to integrate the function in your interface.
Even recently on marlinkimbra a command (M9999) has been introduced to program the board without physically pressing the buttons on the board.
