I/o configuration
i have a self-designed motherboard with the same io layout
with Rumba, except that what I considered a lot is 6 steppers, a heat sensor,
etc ... missed (does not occupy anything except the feet are free)
rumba configur provided (repetier) is completely different to HE0 not where it should be
to switch. But the leads are the same. I checked the arduino several times
compared to the directives io feet + there is a rumba plus panel but the pcb plan can also be downloaded
and all good is just switching from FAN0 to HE0. and the heat sensors also have a problem.
Anyone have an idea for this?
