Layer Height
Since upgrading to Repetier Host 1.2.0 I am unable to adjust layer height through Slic3r. The object sliced will always go to a default layer height. I do not have this problem using the older version of the program. Can anyone help me?
  • Assuming you mean mac host, there is no layer height setting in host. You can change print profile and layer height will be taken from the setting in that profile. Make sure to save the configuration before slicing or it will use last height before you saved the configuration.
