Decoupling nightmares (and a maybe fix)
I'm using v.92, and have been getting decoupling errors off and on for months now. There's nothing wrong with the hardware, the bed would heat up and it would start heating the extruder, but only get halfway to the target temp and I get the decoupling error and it shuts down. I narrowed it down to the bed being the issue, no heated bed, no decoupling errors. Thermistors are fine, heaters are fine, there's no reason for the errors.
What I just found is that if I slice the file with bed heating off, but turn it on MANUALLY, it works just fine. Somehow running the bed heat and extruder heat with code randomly makes it decouple.
No idea why it works, but it does.
Sounds like I should update the firmware in any case.
