Temperature are are shown all negative bed and extruder
Hi together,
so thats my first issue in 3D printing and now i have already a issue with bed and extruder temperature.
I use Firmeware 0.92.9 with ramps 1.4 and my own printer design.
when i connect the temperature sensors both shown room temperature but with negative sign -21 °C.
I have three temp sensors and the behavior is always the same.
In cofiguration file i use Sensor Type 1 (100K NTC).
i would be glad if somebody could help me a little for the right way.
BR
Sven
BR
Sven
Check your wiring, if you have a tester, measure resistance of the thermistor (typically should be close to 100 kOhm), make sure you have correct pin assigned.
To narrow down the problem you can temporarily replace thermistor with 100K resistor directly attached to sensor connector on your board and check if the reading changes.
The thermistor seems to be o.k. I measure 110kOhm (100kOhm=25°C). When I heated up the thermistor with my hand the measured temperature will also goes higher up to 35°C .
It is possible the repetier software show the temperature values always with "minus" in front ? when I look at the temperature curves the value seems to be positiv and the graphical LCD Display show also positive values.
I ´m a little confused now.
