Updated Raspberry Pi Image?
Hi
Current version of the Repetier server is the 0.93.0.
Will or when will the latest version be available as a finished Raspberry Pi Image? There it is still the version 0.92.2
greeting
greeting
When I'm pressing the update button in repetier-server then it shows spinner, but it looks like it's not updating.
Are there any logs what is happening or can I initiate that update in RPi shell, to see immediate feedback?
Auto updates have never worked at home
It is always possible to this also in ssh shell. After login
wget http://download.repetier.com/files/server/debian-armel/Repetier-Server-0.93.0-Linux.deb
sudo dpkg -i Repetier-Server-0.93.0-Linux.deb
is all that the updater does if no firewall/routing problem/... interferes.
Thank you! In ssh shell, I was able to perform the update to 0.93
