problem with bluetooth serial
hi i'm using repetier dev version.
and added this to configuration.h
#define BLUETOOTH_SERIAL 1
#undef ENDSTOP_ZMAX_PIN //clear zmax pin for serial
#define ENDSTOP_ZMAX_PIN ENDSTOP_YMAX_PIN
repetier.h
#define NEW_COMMUNICATION 1
but serial 1 not working
i have some idea but can't find problem
pin config or firmware?
repetier.h
I noticed that in Arduino after replacing the rxtxserial.dll I could see the port and use it perfectly. I then had the idea of putting Arduino RXTXcomm.jar to replace processing one. And bingo processing sees and can use the Bluetooth com port without apparent issue. Only thing is this warning:
WARNING: RXTX Version mismatch
Jar version = RXTX-2.1-7
native lib Version = RXTX-2.2pre2
I hope this helps!
Regards,
Lewis
