Dimension with 5" LCD
We are very numerous in the community to use a 5 inch screen on raspberry, is it normal behavior that the 3D rendering does not occupy more space on the screen?
Is it not possible to enjoy a little more screen because there is a lot of unoccupied black space that could be used to enlarge the rendering it would be really really great !
In addition, the buttons "Continue" and "Stop" are too narrow, it often happens that you do not press the right button according to the calibration of the screen. On the number of image 2, the problem would be solved.
What do you think ?
Like this ? :
Best regards
Jeremy
What do you think ?
Like this ? :
Best regards
Jeremy
Sizes are also difficult to increase. Layout is 2 rows so image height is always the same as the progress here. So here the size is limited. Already thinking about a design change to optimize that screen, but that will be in a later version. When I then have different version for different resolutions I'm more free to optimize the design more.
