X2 motor doesn't move in IDEX
edited October 2019 in Motor Control
I just completed building IDEX printer and stumbled on the following issue with X2 motor:
Homing with G28 works as it should - X1 (left) printhead moves to the left to X-Min position, X2 (right) printhead moves to the right to X-Max position. X1 moves with G0/G1 commands and I have already printed several things using single printhead without issues.
X2, however, does not move after homing. I am trying to make it move by switching to Tool 1 (T1) and executing G0/G1 with different X values. When I execute T1, X1 printhead moves to home position, which is correct. In addition to running manual commands I tried to run GCODE that should print with X2 only, but it still did not move. I suspect I have some kind of issue with my configuration settings and hoping someone can pinpoint me to the culprit.
The image below shows the dimensions of my printer. It is followed by relevant configuration settings. I am using the latest 1.x development version of the firmware.
#define INVERT_X_DIR 1
#define INVERT_X2_DIR 0
#define X_HOME_DIR -1
#define X_MIN_POS -52
#define X_MAX_LENGTH 408
#define EXT0_X_OFFSET 0
#define EXT1_X_OFFSET 52
#define DUAL_X_AXIS 1
#define DUAL_X_RESOLUTION 0
#define LAZY_DUAL_X_AXIS 0
#define DUAL_X_AXIS_MODE 1
  • edited October 2019
    Update:
    Found from this topic that EXT1_X_OFFSET needs to be the distance in steps. Then found ever more info in Configuration.h file.
    Will need to test this:
    #define EXT1_X_OFFSET 32640   // 408 mm * 80 step/mm
  • Yes, both extruders must have offset x set relative to x = 0, so left one needs -52 * 80 = -4160 then.
    I have not seen this being documented anywhere. Will try this setting today. The only partially working combination of settings that I found so far was:
    #define X_MAX_LENGTH 356
    #define EXT1_X_OFFSET 32560   // 407 mm * 80 step/mm
    With these settings X2 could move and cover almost entire print area, however X1 could only move up-to X=304 (356-52).
    Above configuration allowed me to successfully print with single X2 print-head. Then I decided to try ditto mode, but nevertheless ditto was enabled in configuration file, I got error saying M280 is unknown command. But that is a new issue and I may start a separate discussion for it.
  • Here a config for a dual x I once had:
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.0dev
       as you expect.
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 402
    #define RFSERIAL Serial
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    #undef X_MAX_PIN
    #define X_MAX_PIN ORIG_X_MIN_PIN
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 512
    #define YAXIS_STEPS_PER_MM 519
    #define ZAXIS_STEPS_PER_MM 23569
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define DECOUPLING_TEST_MAX_HOLD_VARIANCE 30
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET -22784
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 2230
    #define EXT0_TEMPSENSOR_TYPE 13
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 1
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 45
    #define EXT0_MAX_ACCELERATION 3000
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 18.3
    #define EXT0_PID_I 2.13
    #define EXT0_PID_D 39
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 10
    #define EXT0_SELECT_COMMANDS "G92 E0\nG1 E10 F300\nG1 E8 F1800\nG92 E0\nM117 Extruder 1\nG4 P1000"
    #define EXT0_DESELECT_COMMANDS "G92 E0\nG1 E-2 F1800\nG92 E0"
    #define EXT0_EXTRUDER_COOLER_PIN HEATER_3_PIN
    #define EXT0_DECOUPLE_TEST_PERIOD 30000
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 207206
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 2230
    #define EXT1_TEMPSENSOR_TYPE 13
    #define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
    #define EXT1_HEATER_PIN HEATER_2_PIN
    #define EXT1_STEP_PIN ORIG_E1_STEP_PIN
    #define EXT1_DIR_PIN ORIG_E1_DIR_PIN
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
    #define EXT1_ENABLE_ON 1
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 45
    #define EXT1_MAX_ACCELERATION 3000
    #define EXT1_HEAT_MANAGER 1
    #define EXT1_PREHEAT_TEMP 190
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_PGAIN_OR_DEAD_TIME 18.3
    #define EXT1_PID_I 2.13
    #define EXT1_PID_D 39
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 10
    #define EXT1_SELECT_COMMANDS "G92 E0\nG1 E10 F300\nG1 E8 F1800\nG92 E0\nM117 Extruder 2\nG4 P1000"
    #define EXT1_DESELECT_COMMANDS "G92 E0\nG1 E-2 F1800\nG92 E0"
    #define EXT1_EXTRUDER_COOLER_PIN HEATER_3_PIN
    #define EXT1_DECOUPLE_TEST_PERIOD 30000
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0.5
    #define FILAMENTCHANGE_SHORTRETRACT 1
    #define FILAMENTCHANGE_LONGRETRACT 10
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 13
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   131.1
    #define HEATED_BED_PID_IGAIN   3.76
    #define HEATED_BED_PID_DGAIN 1143.1
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 285
    #define MAX_DEFECT_TEMPERATURE 350
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_Y_BACK_ON_HOME 0
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 1
    #define Y_ENABLE_ON 1
    #define Z_ENABLE_ON 1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 1
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define Y_MAX_LENGTH 274
    #define Z_MAX_LENGTH 230
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_PERMANENT 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define BABYSTEP_MULTIPLICATOR 200
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 400
    #define MAX_FEEDRATE_Y 400
    #define MAX_FEEDRATE_Z 10
    #define HOMING_FEEDRATE_X 100
    #define HOMING_FEEDRATE_Y 100
    #define HOMING_FEEDRATE_Z 10
    #define HOMING_ORDER HOME_ORDER_YZX
    #define ZHOME_PRE_RAISE 2
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 120
    #define ZHOME_Y_POS 120
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 1
    #define DIRECTION_DELAY 0
    #define STEP_DOUBLER_FREQUENCY 80000
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1300
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 300
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 300
    #define MAX_JERK 5
    #define MAX_ZJERK 0.5
    #define MOVE_CACHE_LOW 10
    #define EXTRUDER_SWITCH_XY_SPEED 300
    #define DUAL_X_RESOLUTION 1
    #define X2AXIS_STEPS_PER_MM 400
    #define X2_STEP_PIN   ORIG_E2_STEP_PIN
    #define X2_DIR_PIN    ORIG_E2_DIR_PIN
    #define X2_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define FEATURE_DITTO_PRINTING 1
    #define USE_ADVANCE 1
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 0
    #define FEATURE_Z_PROBE 0
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 30
    #define Z_PROBE_Y_OFFSET 20
    #define Z_PROBE_SPEED 10
    #define Z_PROBE_XY_SPEED 250
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 0
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT ORIG_SDCARDDETECT
    #define SDCARDDETECTINVERTED 1
    #define SD_RUN_ON_STOP ""
    #define SD_STOP_HEATER_AND_MOTORS_ON_STOP 0
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_FAN2_CONTROL 1
    #define FEATURE_CONTROLLER 25
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 1
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Prodim XXL Pro"
    #define UI_PRINTER_COMPANY "V1.0.9"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_HEAD "E:%ec/%Ec\002 B:%eb/%Eb\002"
    #define UI_SET_MIN_HEATED_BED_TEMP  40
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   285
    #define NUM_MOTOR_DRIVERS 0
    // Firmware als basis V1.0.7
    // LAZY_DUAL_X_AXIS 0  >  1 in Repetier.h
    #define LAZY_DUAL_X_AXIS 1
    // Overstap naar Groot scherm > Nu Support voor groot LCD Zie voor veranderingen tabblad LCD 128x64 V1.0.0
    //  RADDS LCD DISPLAY 4x20 naar sparkLCD + adapter on RADDS LCD PORT  + de veranderingen in de tabblad!
    // #define SDCARDDETECTINVERTED van 0 naar 1
    // Logo veranderd naar Prodim in Logo.h
    // #define ENDSTOP_Y_BACK_ON_HOME 10 > 0   (voor groter print bereik in y-as)
    // BED Temperature sensor van 100K EPcos..   naar    PT100 E3D/Ultimaker  (ivm PT100 board ondersteuning)
    // Extr1 Temperature sensor van 100K EPcos..   naar    PT100 E3D/Ultimaker  (ivm PT100 board ondersteuning)
    // Extr2 Temperature sensor van 100K EPcos..   naar    PT100 E3D/Ultimaker (ivm PT100 board ondersteuning)
    // Exotische talen uitgechakeld nu aleen Engels, Duits en Nederlands Beschikbaar.
    // UI_PRINTER_COMPANY Versie nummer V1.0.8 er in gezet.
        "editMode": 2,
        "processor": 1,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 512,
        "yStepsPerMM": 519,
        "zStepsPerMM": 23569,
        "xInvert": "0",
        "x2Invert": 0,
        "xInvertEnable": "1",
        "eepromMode": 1,
        "yInvert": "0",
        "y2Invert": 0,
        "yInvertEnable": "1",
        "zInvert": "1",
        "z2Invert": 0,
        "z3Invert": 0,
        "z4Invert": 0,
        "zInvertEnable": "1",
        "extruder": [
                "id": 0,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 13,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 45,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "1",
                "acceleration": 3000,
                "watchPeriod": 1,
                "pidP": 18.3,
                "pidI": 2.13,
                "pidD": 39,
                "advanceK": 0,
                "advanceL": 10,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 2230,
                "coolerPin": "HEATER_3_PIN",
                "coolerSpeed": 255,
                "selectCommands": "G92 E0\\nG1 E10 F300\\nG1 E8 F1800\\nG92 E0\\nM117 Extruder 1\\nG4 P1000",
                "deselectCommands": "G92 E0\\nG1 E-2 F1800\\nG92 E0",
                "xOffset": -44.5,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": -22784,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 30,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
                "id": 1,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 13,
                "sensorPin": "TEMP_2_PIN",
                "heaterPin": "HEATER_2_PIN",
                "maxFeedrate": 45,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 18.3,
                "pidI": 2.13,
                "pidD": 39,
                "advanceK": 0,
                "advanceL": 10,
                "waitRetract": 0,
                "stepsPerMM": 2230,
                "coolerSpeed": 255,
                "selectCommands": "G92 E0\\nG1 E10 F300\\nG1 E8 F1800\\nG92 E0\\nM117 Extruder 2\\nG4 P1000",
                "xOffset": 404.7,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 207206,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 1",
                    "step": "ORIG_E1_STEP_PIN",
                    "dir": "ORIG_E1_DIR_PIN",
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 2,
        "yMinEndstop": 2,
        "zMinEndstop": 2,
        "xMaxEndstop": 2,
        "yMaxEndstop": 0,
        "zMaxEndstop": 0,
        "x2MinEndstop": 0,
        "y2MinEndstop": 0,
        "x2MaxEndstop": 0,
        "y2MaxEndstop": 0,
        "motherboard": 402,
        "driveSystem": 0,
        "xMaxSpeed": 400,
        "xHomingSpeed": 100,
        "xTravelAcceleration": 3000,
        "xPrintAcceleration": 1300,
        "yMaxSpeed": 400,
        "yHomingSpeed": 100,
        "yTravelAcceleration": 300,
        "yPrintAcceleration": 300,
        "zMaxSpeed": 10,
        "zHomingSpeed": 10,
        "zTravelAcceleration": 100,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 356,
        "yLength": 274,
        "zLength": 230,
        "alwaysCheckEndstops": "0",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 1,
        "yEndstopBack": 0,
        "zEndstopBack": 0,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 1,
        "directionDelay": 0,
        "stepDoublerFrequency": 80000,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 5,
        "maxZJerk": 0.5,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "1",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": "0",
        "mirrorXMotor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "dittoPrinting": "1",
        "featureServos": "0",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "1",
        "hasHeatedBed": "1",
        "enableZProbing": "0",
        "extrudeMaxLength": 160,
        "homeOrder": "HOME_ORDER_YZX",
        "featureController": 25,
        "uiPrinterName": "Prodim XXL Pro",
        "uiPrinterCompany": "V1.0.9",
        "uiPagesDuration": 4000,
        "uiHeadline": "E:%ec\/%Ec\\002 B:%eb\/%Eb\\002",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiMinHeatedBed": 40,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 285,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 13,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 1,
        "bedPreheat": 55,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 131.1,
        "bedPidI": 3.76,
        "bedPidD": 1143.1,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100,
        "gen1Beta": 500,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 4700,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 4700,
            "r2": 4700,
            "temps": [
                    "t": 0,
                    "r": 100,
                    "adc": 83.5714285714
                    "t": 10,
                    "r": 103.9,
                    "adc": 86.6927136395
                    "t": 20,
                    "r": 107.8,
                    "adc": 89.8040930914
                    "t": 30,
                    "r": 111.7,
                    "adc": 92.9056140066
                    "t": 40,
                    "r": 115.5,
                    "adc": 95.9181707564
                    "t": 50,
                    "r": 119.4,
                    "adc": 99.000364461
                    "t": 60,
                    "r": 123.2,
                    "adc": 101.994177584
                    "t": 70,
                    "r": 127.1,
                    "adc": 105.057224173
                    "t": 80,
                    "r": 130.9,
                    "adc": 108.032468056
                    "t": 90,
                    "r": 134.7,
                    "adc": 110.998611502
                    "t": 100,
                    "r": 138.5,
                    "adc": 113.955696203
            "numEntries": 11
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 285,
        "minDefectTemp": -10,
        "maxDefectTemp": 350,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "featureFan2Control": "1",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbePin": "ORIG_Z_MIN_PIN",
        "zProbeBedDistance": 10,
        "zProbeDisableHeaters": "0",
        "zProbePullup": "1",
        "zProbeOnHigh": "0",
        "zProbeXOffset": 30,
        "zProbeYOffset": 20,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 10,
        "zProbeXYSpeed": 250,
        "zProbeHeight": 0,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "0",
        "zProbeX1": 20,
        "zProbeY1": 20,
        "zProbeX2": 160,
        "zProbeY2": 20,
        "zProbeX3": 20,
        "zProbeY3": 160,
        "zProbeSwitchingDistance": 1,
        "zProbeRepetitions": 1,
        "zProbeEveryPoint": "",
        "sdSupport": "1",
        "sdCardDetectPin": "ORIG_SDCARDDETECT",
        "sdCardDetectInverted": "1",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MIN_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 200,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": -1,
        "mixingExtruder": "0",
        "decouplingTestMaxHoldVariance": 30,
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionR": 100,
        "distortionPermanent": "0",
        "distortionEndDegrade": 1,
        "distortionXMin": 10,
        "distortionXMax": 190,
        "distortionYMin": 10,
        "distortionYMax": 190,
        "sdRunOnStop": "",
        "sdStopHeaterMotorsOnStop": "0",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0.5,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "filamentChangeShortRetract": 1,
        "filamentChangeLongRetract": 10,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 1,
        "primaryPort": 1,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertEnable": "0",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        &nbsp
  • For M280 you need
  • Thanks for sharing your configuration. That will definitely help and save me time.
    As for FEATURE_DITTO_PRINTING, yes, I have it set to 1, but still getting unknown command error, which is strange. Will double check all the settings later today.
  • @Repetier Many Thanks!!! My printer is finally up and running in Ditto mode!
    I just want to add few notes for those who may be facing similar issues:
    - Earlier in this thread I wrote that the fact that "both extruders must have offset x set relative to x = 0" is not documented anywhere. Actually, it is mentioned in configuration.h file, but it applies only to DUAL_X_AXIS legacy mode. I chose to use "new mode" with DUAL_X_AXIS_MODE = 1 and did not pay attention to the above comment about offsets, since it does not apply to my setup. If you decide to use legacy mode - follow this rule.
    - The settings that allowed me properly switch between 2 X-motors and position cartridges anywhere within print area are:
    #define DUAL_X_RESOLUTION 0 //same resolution so 0
    #define X2AXIS_STEPS_PER_MM 80
    #define X_MAX_LENGTH 407.95
    - The issue I had earlier with M280 command went away after re-flashing firmware with EEPROM switched off. Not sure if this was related. I will re-enable EEPROM later and re-test.
    One remaining question I have is about print-head positioning in ditto mode:
    After executing M280 S1 both print-heads move towards corresponding ends-stops and then X2 moves left close to the middle of the bed. X1 remains at parked position. As the result, in my case, the distance between two nozzles in ditto mode is about 255mm. I'd expect it to be half the print area width, 356 /2 = 178mm. Am I still missing something, or this is expected for 1.x dev version?
  • Here how M280 activates right extruder:
    -Extruder::current->xOffset + static_cast<int32_t>(Printer::xLength * 0.5 * Printer::axisStepsPerMM[X_AXIS])
    That is -204mm and ext0 would be at x=0 (not at parked pos -52).
    Not 100% sure if that is an error with the new mode allowing to move beside 0 point. Here we get in trouble I guess with that mode. You can not print left to 0 but should we assume same offset to right exruder? We do not know where the bed really ends. Guess adding that offset would be more correct here.
    On the other side X_MAX_LENGTH is measured from X_MIN_POS so I think more that X_MAX_LENGTH should be 460 instead. It is not X_MAX_POS if bed is 356mm wide.
  • Thanks for pointing out the exact place in the code. I was able to fix the issue by simply adding Printer::xMinSteps value to the end. So the line looks like this:
    PrintLine::moveRelativeDistanceInSteps( -Extruder::current->xOffset + static_cast<int32_t>(Printer::xLength * 0.5 * Printer::axisStepsPerMM[X_AXIS]) + Printer::xMinSteps, 0, 0, 0, EXTRUDER_SWITCH_XY_SPEED, true, true);
    My above calculation was incorrect. For each printhead to cover half of bed area along X the distance between nozzles in ditto mode has to be half of X_MAX_LENGTH, so 204 mm in my case.
    Above code appears in 4 files
    \src\ArduinoDUE\Repetier\Commands.cpp
    \src\ArduinoDUE\Repetier\ui.cpp
    \src\ArduinoAVR\Repetier\Commands.cpp
    \src\ArduinoAVR\Repetier\ui.cpp
    I am using ArduinoDUE branch and currently do not have LCD, so I just updated only the 1st file in above list in my local copy. Hopefully this change does not break legacy and/or lazy modes and can be applied as a fix.
  • How did it work with my other simple solution to use correct x length? SHould have added the same distance, so what was wrong with that solution?
    Your other solution is for LAZY mode that I am currently not using. With LAZY mode on, at M280,  X1 moves to X=0
    #if LAZY_DUAL_X_AXIS
                PrintLine::moveRelativeDistanceInSteps(-Extruder::current->xOffset, 0, 0, 0, EXTRUDER_SWITCH_XY_SPEED, true, true);
    #endif
    But if LAZY_DUAL_X_AXIS is set to 0, X1 remains at parked position  and X2 should move further left. This actually  means that my change is needed only in new mode with LAZY mode switched off.
    The description of dual x settings in configuration.h file gives an impression that LAZY_DUAL_X_AXIS setting  applies only to DUAL_X_AXIS_MODE=0 (legacy mode). LAZY_DUAL_X_AXIS is not mentioned under new mode description at all. After checking the code I realized that this may not be the case.
    I am planning to run more tests. I will try both - legacy and new modes with and without lazy mode and will report the results.
    Today I finally found the reason of the initial problem reported here. Since the topic of this discussion slightly shifted, I created a separate post to keep it short and not to confuse other users.
