What did you change and do to fix it? This is definitively underextrusion so check extruder calibration and also slicer setting if the multiplier is low. Check flow multiplier to be 100 normally. For testing set it to 200 and see if it gets better. Looks a bit like you get only half of the needed extrusion. In any case you must find which setting is so wrong that it causes massive underextrusion. Also a too cold nozzle can be the problem. Then your filament just slips regardless how much you increase extrusion.
Apart from the fact that a bed should not vibrate off course, how does it cause under extrusion?
