Does everything except work.
I have Repetier Host loaded into my Geetech Anet A8 modified.
I can load .stl files or G-code, slice and hit the print button, all happily enough, but the actual printing part isn't happening.
It even heats the bed and extruder up to temperature, all ready to go, but it simply won't start.
I can home all the axes, so the motors work.
Something obvious perhaps?
Help!
Help!
If you enable commands view you also see if the host has send commands of the gcode.
Especially if communication already works it is something that you can see in the log if you know what to watch for.
I actually reflashed the firmware eventually, after staring at the log file for far too long.
It is working beautifully again now.
The more I understand this firmware, the more of a fan I become.
Cheers!
