problem with Z-homing
Hi everybody,
I have built a modified version of TAZ printer. It worked well up to now as I was using Z-max end stop. I am trying to switch to Z-min end stop but I am getting a problem. I think it is my problem as I am missing something very simple. When I home z axes it behaves correctly, hits the end stop (optical), backs up, does it second time and after it moves head up for 2 mm as it written in configuration file. t this point the host shows Z=0, if in settings of printer shape in host Z home is =0. If I change this number to 2, then host shows z=2 mm. Up to this point everything seems logic and correct. But when after this I try to move Z to a new hight, lets say 10 mm then first it moves head 2 mm and only after it to another 10 mm. Result is that my head now is at 14 mm instead of 10 mm.
Same thing happens with two other axes, but those could be managed by moving end stops. In case of Z axes, the end stop can not be moved lower, as the head will push on bed.
Please help, I can not understand what I am doing wrong.
My printer is XY cartezyan printer with 320 x 320 mm heated bed, Z is 220 mm. It has a MKS-Base motherboard, 3 optical end stops, Repetier firmware 1.0.2, Below is part of my config file.
Thank you very much, Simon
#define ENDSTOP_PULLUP_X_MIN false
#define ENDSTOP_PULLUP_Y_MIN false
#define ENDSTOP_PULLUP_Z2_MINMAX false
#define ENDSTOP_PULLUP_X_MAX false
#define ENDSTOP_PULLUP_Y_MAX false
#define ENDSTOP_PULLUP_Z_MAX false
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_Z_BACK_ON_HOME 1
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 320
#define Y_MAX_LENGTH 320
#define Z_MAX_LENGTH 220
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 150
#define PARK_POSITION_Y 150
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 310
#define DISTORTION_YMAX 310
// ## Movement settings ##
You did not show z probe settings. Important is that you do not have any moves in z probe scripts. These would mess up positions during homing.
should be 0. This means it should go up 1mm from the real bed level, but that is bad here. It was ok for z max probing to not trigger the end stop, but on bottom we do want to know bed level. Use z probe bed height to calibrate correct distance after probing. Use G30 to test it Take a metal block or drill with known thickness and move z so that it just lightly touches the object. Run G30 to see what distance gets measured and modify z probe height until you get the height of the block. Only with calibrated z probe you can expect homing to be correct.
After G28 you see in log the homing position assumed by firmware. Use this in host so host assumes the same position.
Hope one of these already covers the problem.
Thanks for quick response and very good advise. I don't have Z-probe, and did not change anything in Z-probe settings.
I tested your suggestions and they worked. I was afraid that if head will stay at Z=0 it will trigger the z-min end stop.
Thanks again for great help.
Simon
