G32 Error on Kossel (Delta)
After recently re-flashing firmware with Repetier .92 on my Delta I went to autolevel (G32) and start in to some basic calibration stuff again when I hit this brick wall. I noticed that it was giving me an Error:ng byte early in the command but it kept going like there was no issue. Then after a few probes around the center (not using a grid but oddly probing two spots adjacent to each other near the center) it would "pause" the print job. After I unpaused, it kicked a whole bunch more errors and I'm pretty sure just thought it had plowed in to the bed so it wouldn't move until I reset it. Log to follow:
I've tried returning my EEPROM to default and nothing works. Other commands seem to work fine but and I can heat things up, cool them down, etc.
18:02:02.702 : OpenGL version:4.5.0 - Build 23.20.16.4973
18:02:02.703 : OpenGL extensions:GL_3DFX_texture_compression_FXT1 GL_AMD_depth_clamp_separate
18:02:02.703 : OpenGL renderer:Intel(R) HD Graphics 530
18:02:02.703 : Using fast VBOs for rendering is possible
18:02:05.315 : Printer reset detected - initializing
18:02:05.329 : start
18:02:05.329 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
18:02:05.591 : Free RAM:1366
18:02:05.591 : Autoretract:0
18:02:05.593 : X:0.00 Y:0.00 Z:0.000 E:0.0000
18:02:05.594 : SelectExtruder:0
18:02:05.606 : FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
18:02:05.606 : Printed filament:137.47m Printing time:1 days 6 hours 11 min
18:02:05.606 : PrinterMode:FFF
18:02:05.622 : X:0.00 Y:0.00 Z:0.000 E:0.0000
18:02:05.622 : DebugLevel:6
18:02:05.622 : SelectExtruder:0
18:02:05.622 : Begin file list
18:02:05.623 : End file list
18:02:05.624 : DebugLevel:6
18:02:05.625 : SelectExtruder:0
18:02:10.699 : SelectExtruder:0
18:02:10.706 : X:0.00 Y:0.00 Z:300.000 E:0.0000
18:02:22.669 : SelectExtruder:0
18:02:22.675 : X:0.00 Y:0.00 Z:300.000 E:0.0000
18:02:22.678 : Error:ng byte
18:02:31.638 : Z-probe:7.49 X:0.00 Y:0.00
18:02:34.645 : Z-probe:7.48 X:0.00 Y:0.00
18:02:37.797 : Z-probe:7.56 X:4.30 Y:0.00
18:02:39.305 : plane: a = NAN b = NAN c = NAN
18:02:39.308 : Transformation matrix: NAN NAN NAN NAN NAN NAN NAN NAN NAN
18:02:39.309 : CurrentZ:NAN atZ:5.00
18:02:39.310 : Z after rotation:5.00
18:02:39.310 : Printer height:NAN
18:02:39.312 : Error:A hit floor
18:02:39.313 : Info:Autoleveling enabled
18:02:39.313 : Error:G32
18:02:39.314 : X:NAN Y:NAN Z:NAN E:0.0000
18:02:39.316 : Info:Autoleveling disabled
18:02:39.343 : RequestPause:Homing failed!
18:02:39.346 : Error:A hit floor
18:02:39.346 : Warning:Invalid delta coordinate - move ignored x:0 y:0 z:2147483548
18:02:39.346 : Warning:in queueDeltaMove to calculateDeltaSubSegments returns error.
18:02:39.346 : Warning:moveRelativeDistanceInSteps / queueDeltaMove returns error
18:02:39.348 : SelectExtruder:0
18:02:39.348 : X:0.00 Y:0.00 Z:-21474836.000 E:0.0000
18:02:39.348 : Info:Autoleveling enabled
18:02:46.470 : Error:isPositionAllowed
18:02:46.472 : X:NAN Y:NAN Z:NAN E:0.0000
18:02:46.473 : Error:isPositionAllowed
18:02:46.473 : X:NAN Y:NAN Z:NAN E:0.0000
18:02:46.476 : Error:isPositionAllowed
18:02:46.477 : X:NAN Y:NAN Z:NAN E:0.0000
NAN is Not a Number so seeing it means you operate with illegal numbers. Most likely eeprom not having meaningful content. Try uploading with different EEPROM_MODE to force reinitialization.
I'm not sure I understand what operating "with illegal numbers" means. I'll try an old EEPROM set I saved from an old firmware boot but I don't see how that would help unless the problem itself was EEPROM related, which from your earlier comment, it's not.
Second, I don't know how I would find a forgotten PSTR in the message print...
I hope I'm not bothering anyone too much. Thank you in advance.
M502
M500
from host which does at least in theory the same, also I'm quite sure it does not reset e.g. autoleveling matrix or distortion matrix. So you might want to recreate them with G32/G33 if you use them.
Forgot the PSTR thing. That is more an explaination why message is wrong, nothing you need to fix.
https://pastebin.com/biVu1wBK
Basically the same errors as before. I'll just attach my firmware to try and expedite this hopefully.
https://drive.google.com/open?id=1yGSlIkKXIRKiqcN15VWGUQ5kDvT49WA3
I have tried generating my own firmware using the builder but honestly, it makes more problems than solutions as I am too inexperienced. If this firmware is simply too messed up or outdated (and thus the problem), could you help me to create a more updated version?
Upgrading if you used the config tool is easy. Just upload old configuration.h to e.g. dev version and tool will add new settings with good defaults. So it is just an upload and download of new version which is what I'd try first.
Your log does not contain commands so I do not see what you send to get the NAN. Interesting would be
G28
M114
and see if that works.
"No valid configuration from previous session found. Looks like you have uploaded a plain configuration.h and not a version generated with the configuration tool."
Accidentally had my commands off because I got frustrated with the M105's, sorry. The commands causing the NAN are G29 and G32. G33 is not in my firmware it appears, likely an edit by the manufacturer.
To use the config tool you in deed need a version created with it or tool will not know the settings in it. So upgrading is a bit more complicated. You see how the defines are named in tool but need to check all manually in config file and enter them.
Again, I understand the premise of how to use the config tool but my old config file doesn't work and I am too unskilled to do it myself manually. I have tried before and I didn't know enough and/or missed values and I had to roll back my firmware to square 1... Is there anywhere I can get help to get updated/ upgraded genuine Repetier firmware? At this point I will honestly pay for it, I'm feeling kind of hopeless.
