Ultimaker 2+ with Repetier Server
Hi there and hello all,
I am slowly getting to grips with Repetier Server and have managed to get it working really well with a Prusa i3. I have no such luck with a older ultimaker 2 or 2+. I know the firmware has to be Marlin. I have tried tinkergnome firmware upgrade (not sure if this is a "Marlin" firmware upgrade) but I still have not been able to get it working.
I can get it to connect but nothing more.
Is there any users out there who have managed to get the Ultimaker 2's working with Rep Server? If so, where can I get the right firmware upgrade, and what connection settings worked for you?
Thanks in advance
Thanks in advance
Many Thanks, Dave
All other settings same as in host should work. There is no copy of settings between them. Also important on windows only one software can connect to a port. So make sure no other is connected (e.g. host with regular serial connection, server connector does not count here).
It is working now.
Take Care, Dave
