BLTouch in delta Micromake D1
Hi!
I am just trying to set up the bltouch on my delta printer Micromake D1. The thing is that I made it work; when I send the commands "M340 P0 S700" and "M340 P0 S1500" is moving up and down but when I send G29 or G33 the metallic part of the sensor is not going down.
If I move the Touch by gcode sending "M340 P0 S700" and then run G29, it is working but I got the next error (but I also get the measurements):
19:17:51.930 : Error:
19:18:04.294 : Z-probe:7.62 X:30.00 Y:-20.00
19:18:11.375 : Z-probe:9.82 X:10.00 Y:30.00
19:18:18.573 : Z-probe:6.65 X:-3.00 Y:-35.00
19:18:19.397 : Error:
19:18:19.829 : Z-probe average height:8.03
19:18:19.833 : X:-3.00 Y:-35.00 Z:3.820 E:0.0000
19:18:19.833 : Error:
I guess I need to set somewhere in the firmware my Zmin as "electronic, normally closed" but I don't know where.
If you could tell me if the issue is due to that and how to solve it I will be really thank you!
The error messages seem strange as there is no error message.Normally there is. Are you using dev version (1.0.4)?
