G33 Distortion Correction Add Points
Is it possible to add points to the distortion map? I have an older delta and there seems to be a small area of the bed that does not get corrected as well as all the rest. Meaning in that area (about 25mm x 25mm) the first layer seems to drag the nozzle on the glass (too thin of a layer). I am wondering if I can force a correction point at or near that location. I can see the adjustment possibility in the G33 command for existing points. Can I add to this or increase to probe density (more points)? Does BED_LEVELING_GRID_SIZE control this? I use BED_LEVELING_METHOD 0, which only measures the three points. G33 uses the grid correct?
Thanks in advance. Running 0.92.9 Firmware.
