Davinci Duo 2.0A not extruding while printing.
I seem to have a problem with my Davinci Duo 2.0 since it is not extruding anything when it starts to print. I can manualy make it extrude through the Repetier Host, but when I try to print something nothing comes out?
  • Correct firmware in slicer selected so it has extrusion using E and also set extursion mode to relative/absolute depending on what you configured? Dry run disabled?
  • I have the same problem with my DaVinci 1.0. Can you suggest a fix?
