Create a solid base layer for elevated objects
I'm trying to figure out how to create a solid base layer to start elevated prints on, basically anything where the main body is elevated and a few small parts touch the bed, I can't get a good stick all around. Everything I print with a solid base that's flat on the bed prints perfect. So how do I go about building my rafts and support material off of a solid layer or 2 without creating the base within the 3D imaging program I'm using(how I've been doing it so far)? I'll repeat this as clear as I can. Is there a way to create solid layers before rafts using Slicer? Or any other slicing tool for that matter.
If your problem is that it does not stick good enough for sparse prints you do something wrong or it can be improved.
- Use correct bed temperature for material
- Use correct filament temperature
- Check distance. If gap is too big it sticks much less then when you are close.
- Change bed material that works better or add spacial 3d printer spray, glue, other surface like BuildTak or alternatives.
I actually never print with rafts and it works good as everythings sticks well to bed.
