Bad value for Z counter, after G28
I recently upgrade the firmware (1.03) and the host (2.1.3). Before I used Host 2.0.5 and firware 0.92.9. with the same parameters.
And since that, after using G28 command for Z home, I reveive Z:0.00 instead of Z:10.00
My setup :
- Endstop distance after homing X:20 Y:20 and Z:10
- X min position : 20
  Y min position : 20
  Z min position  : 0
Could you help me to understand the problem ?
  • In host printer settings you can define homing position now. Enter your homing position there so host knows where you are after G28. Default is 0 which is not true with your settings.
  • Hello,
    I did it !  But without any change.
  • Have to test this if it is really not helping. But that is exactly the place which I meant. Of course you need to rehome after changing it. Can you provide a log with commands enabled of your homing. Maybe it is sending a position before it has finished and reports right coordinates.
  • Just after sending the home command, the counter are like that :
    The log :
    19:44:25.465 : N15 G28*39
    19:44:45.701 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    And finally :
  • Ok, so it is firmware sending wrong position as you say you are at 20, 20, 10 after homing is finished and host adjusts to that once it reads the position from firmware. So host is ok, firmware wrong. Can you try 1.0.4 firmware (dev version) to see if it does it right. Will also try later I hope to see what my config shows after G28. I think my printer also stops a z=10, so should show same problem hopefully.
  • Just tested 1.0.4 aka dev version
    15:17:45.278: N9342 G28
    15:17:45.283: Z correction disabled
    15:17:45.287: Info:Marked all extruders as unjammed.
    15:17:45.291: Jam control disabled:1
    15:17:45.291: Cold extrusion allowed
    15:17:45.409: SelectExtruder:1
    15:17:45.815: Cold extrusion disallowed
    15:17:45.864: SelectExtruder:0
    15:17:46.270: Jam control disabled:0
    15:18:07.545: X:0.00 Y:245.00 Z:10.000 E:0.0000
    So at least there it reports the correct coordinates.
  • edited May 2019
    I have a compiler error with 1.0.4dev (Arduino 1.8.9 - Board Mega 2560) with    "#define EEPROM_MODE 1"
        sketch\Eeprom.cpp: In function 'initalizeUncached':
        sketch\Eeprom.cpp:588:1: internal compiler error: Segmentation fault
    But it's all right with "#define EEPROM_MODE 2"
  • Could you tell me the signification of :   #define MOVE_Z_WHEN_HOMED  ?
    #define ENDSTOP_X_BACK_ON_HOME 20
    #define ENDSTOP_Y_BACK_ON_HOME 20
    #define ENDSTOP_Z_BACK_ON_HOME 10
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
  • Whatever I do,  firmware sending wrong position after G28...
  • Switch of eeprom mode has no real effect but seems that it does not cause compiler to crash, so ok.
    MOVE_Z_WHEN_HOMED means move z only when z is homed.
    ENDSTOP_X_BACK_ON_HOME after homing add extra distance to end stop.
    You might try in firmware Printer.cpp around line 2210 to move  Commands::printCurrentPosition(); to a later line so that it looks like:
    updateHomedAll();
    UI_CLEAR_STATUS
    #if defined(SUPPORT_LASER) && SUPPORT_LASER
    LaserDriver::laserOn = oldLaser;
    setNoDestinationCheck(nocheck);
    Printer::updateCurrentPosition();
    #endif // Not delta printer
    to be on safe side to get it. Can't say why this is not reporting the right position except it is the correct position.
    MOVE_Z_WHEN_HOMED 10 would end at z=0 but it would be z=0 for firmware. For z min homing that value should be 0.
  • I tried to move Commands::printCurrentPosition(); to a later line (firmware 1.03), but it's the same issue.
    Could you look at the Configuration.h file ?
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 701
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    #define FAN_THERMO_THERMISTOR_TYPE 0
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 1600
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 1500
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_MAX_ACCELERATION 1000
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_WAIT_RETRACT_UNITS 5
    #define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 1500
    #define EXT1_TEMPSENSOR_TYPE 8
    #define EXT1_TEMPSENSOR_PIN TEMP_1_PIN
    #define EXT1_HEATER_PIN HEATER_2_PIN
    #define EXT1_STEP_PIN ORIG_E1_STEP_PIN
    #define EXT1_DIR_PIN ORIG_E1_DIR_PIN
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_MAX_ACCELERATION 1000
    #define EXT1_HEAT_MANAGER 1
    #define EXT1_PREHEAT_TEMP 190
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_WAIT_RETRACT_UNITS 5
    #define EXT1_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 0
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 100
    #define HEATED_BED_SENSOR_PIN TEMP_3_PIN
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    #define MAX_DEFECT_TEMPERATURE 2900
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_X_BACK_ON_HOME 25
    #define ENDSTOP_Y_BACK_ON_HOME 25
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 1
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 1
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 200
    #define Z_MAX_LENGTH 200
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 100
    #define PARK_POSITION_Y 20
    #define PARK_POSITION_Z_RAISE 20
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 20
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 2
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define ENABLE_POWER_ON_STARTUP 0
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 40
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT ORIG_SDCARDDETECT
    #undef SDCARDDETECTINVERTED
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 0
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 1
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 1
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 1
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 1
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
  • Firmware 0.92.9 - Host 2.13
        X min pos : 25
        Y min pos : 25
        Z min pos : 10
    Host 2.13
       Config printer  Home X : 25   /  Home Y : 25  /  Home Z : 10
    After G28, the firmware return good values (25 / 25 / 10) and I can go down Z from 10 to 0.
    For the same parameters with Firmware 1.03, after G28 the firmware return good values (25 / 25 / 10) but I can't go down Z from 10 to 0.
  • Looks like you did not understand me since the error is what you already thought:
    That says after homing move x mm back again and assume that position as 0. So firmware is right and you are at 0,0,0. At least ENDSTOP_Z_BACK_ON_HOME must be 0 and the others I'd reduce to 2 maximum just to prevent hitting the endstop at x and y = 0.
    If you want to be at a higher Z after homing choose a homing order with temperatures, set temperature to 0 and
    #define ZHOME_HEAT_HEIGHT 10
    I think that is why my printer is at z=10 after homing.
