Print time calculation with Prusa i3 MK3
I added my Prusa i3 MK3 to my print server. The assistent got the accelerations from the firmware. However the print time is wrong.
The slicer from Prusa says about 1h, for instance, then it's about 11-12h on the repetier server.
I tried to set the print time multiplier to "0.1", then it's better, bat far from good.
Has anybody an idea what the problem could be?
I made a guide, showing how I setup the printer.
https://andreas-reitberger.de/knowledgebase/prusa-i3-mk3-mit-repetier-server-pro/
Thanks!
Thanks!
thanks for the reply. I just set the motion acceleration to 10.000 to see if the time changes. But it didn't.
I'll try the temp. timing wizard. Maybe this will solve the problem.
I'll keep you posted! Thanks for helping out.
Best,
Andy
I made the temp. calibration, however the print time is still wrong. I set the multiplicator back to 1. Now it says 13h for a 1h:30min print job.
I did select the "RepRapFirmware". Is this accurate for the prusa?
Thanks for helping!
sorry for the long wait. I sliced this nozzle organizer.
https://www.thingiverse.com/thing:3604327/files
Prusa Slic3r says: 8h 11 min for this print job.
Here is the gcode file
https://drive.google.com/open?id=1be4Bhih5hfmsEv70HzWHvccVAtfKnR-l
Here is what the print time calculation says on repetier server.
Thanks for looking into this!
Prusa_i3_MK3.zip
https://drive.google.com/open?id=1W438UhBdDsfVsjDP0l3Y1TPlmBO3Basc
M203 X200 Y200 Z12 E120 ; sets maximum feedrates, mm/sec
Now in marlin unit is mm/s but for reprapfirmware it is mm/min so you reduced printer for computation to very slow speed.
Unfortunately changing firmware type does not recompute times. Wasn't aware that it has timing influence. So change a acceleration by 1 to force recalculation of print times for uploaded gcodes. Then they should be in correct range once you have selected Marlin firmware.
Thanks for helping out. Now it's working fine!
What I got from reading this is this. If you buy a 3d printer that recommends this software GO ELSE WHERE IT IS NOT SET UP FOR YOUR PRINTER. Which means They need to stop promoting this software with printers as it is absolute garbage! 1hr to 11hr? yeah its the speed setting of YOUR software cant be us no no no deflect deflect lay blame else where etc bad service
