Repetier-Server for farm
Hi!
I have about 15 printers that I would like to combine into a farm.
I think to install on each printer an Orange Pi Zero with a "Repetier-Server" or "octoprint" software.
And use one pc to control all printers.
Is it possible to get a single dashboard for all devices available on the network?
Will I need to buy a PRO version for each micro PC? Or can I install one license for everyone?
What can you recommend in my case?
Our pro package includes 5 licenses, so you can install it on 5 installations. If you use one pi for 3 printers (server supports multiple printers per device) that would be enough. Otherwise you need 3 pro licenses for 15 installations.
Hi!! When do you think that release this version¿? Just this week i have to start with something like this using several licenses, about 20 printers to start. A simple dashboard that collect all server instances.
Thanks for advice.
Regards.
No release date yet but will be end of may/beginning of june. Then you just update the servers to 0.92.0 and install the desktop app and tell it your server addresses.
Thanks!
But I think it increases likelyhood of bigger failure if you have a problem on ethernet. Then all printers will fail. On the other side ethernet is quite stable normally. Only if it's same as router is on a router restart might hurt.
There's so much time in this configuration, I'll share it when finished.
(Sorry for the bad quality in images)
