RADDS & TMC2208
Hi all,
I am about to build up a new (small) CoryXY printer with TMC2208 on all Steppers.
Recently I came across the "sensorless Homing" feature for TMC drivers. This is very interessting for X/Y axis.
But I do have some questions about Repetier Firmware 1.x(dev):
1: Are TMC2208 supported via UART?
2: If yes, any suggestions which pins to use for RADDS&DUE? Can I use any digital pin?
The Printer is in build state (all axis moving so far) and I do have some TMC2208, so I could do Alpha/Beta testing if needed.![;) ;)](/resources/emoji/wink.png)
Unfortunately V2 is not supporting CoreXY as far as I know, so is no option.
V2 supports CoreXYZ in any combination you like. But also there are no TMC drivers at the moment included also this is a planned feature.
What a pity. But I'm also afraid changing to Marlin just because of this...
Repetier does not support sensorless homing? Neither 2130 nor 2208, neither on V1.x nor V2.x?
But V2 does support CoryXY? I'm using Ramps-/Radds+Due on my printers, 32bit.
This is something new to me. Great news, I need to try V2.
Is there a feature comparision sheet between V1 and V2? I expect that not all features from V1 are working in V2 right now...
