Rendering problems: missing chunks of filament in 3D preview
since a few versions of Repetier Host I experience some rendering issues which cause chunks of filament not beeing rendered. I double checked: it is though actually printed and other gcode viewers render it quite fine. I can't remember when this issue came up.
I'm using Repetier Host V2.1.3 on Windows with an NVIDIA Quadro P1000 Graphics card.
Is this a known issue?
There are also cases where this comes form slicer with intention. Knowing they leak from pressure they stop extruding. If you enable travel moves you then should see a line there. But since it looks like a regular system and not all layers have the gap I assume it is the bug.
