Laser enable pin issue
Hello there.
I'm trying to use the Repetier Firmware with a laser for the first time.
I'm using RAMPS 1.4.
I have powered the laser properly.
Set M452
M3 then moved but nothig happens.
Firstly I chose digital pin 1 (in aux 1) nothing
digital pin 0 (in aux 1) nothing.
digital pin 4 (in servos) laser flashes very fast at movement start (servo support are activated)
I chose digital pin 63 (in aux 2) then it started working.
Questions:
1. Why I cant choose pin 0 or 1?
2. Can I activate the laser in FFF mode? (M451)
3. Can I activate the laser with the printer stoped? (just curiosity)
4. How can I have PWM for the laser? It says to use a driver, but I dont know how.
Follows the configuration.h
Thank you very much!
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   This file is optimized for version 1.0.3dev
   as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 33
#include "pins.h"
#define HOST_RESCUE 1
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 100
#define YAXIS_STEPS_PER_MM 100
#define ZAXIS_STEPS_PER_MM 2560
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 370
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define TEMP_GAIN 0
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_SENSOR_TYPE 4
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define HEATED_BED_PID_IGAIN   33
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ##                             Laser configuration                                      ##
automatically disabled.
#define SUPPORT_LASER 1
#define LASER_PIN 63
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 5
// ##                              CNC configuration                                       ##
#define SUPPORT_CNC 1
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 2
#define ENDSTOP_Y_BACK_ON_HOME 2
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR 1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 300
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 0
#define PARK_POSITION_Z_RAISE 0
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ##                           Movement settings                                          ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 300
#define MAX_FEEDRATE_Y 300
#define MAX_FEEDRATE_Z 7.5
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define HOMING_ORDER HOME_ORDER_XYZ
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 30
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 30
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define Z4_STEP_PIN   ORIG_E3_STEP_PIN
#define Z4_DIR_PIN    ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
#define FEATURE_SERVO 1
#define SERVO0_PIN 11
#define SERVO1_PIN 6
#define SERVO2_PIN 5
#define SERVO3_PIN 4
#define UI_SERVO_CONTROL 1
#define MAX_FAN_PWM 255
        #define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 0
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 40
#define Z_PROBE_DELAY 0
#define FEATURE_AUTOLEVEL 0
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 20
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 1
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define LANGUAGE_RU_ACTIVE 0
#define UI_PRINTER_NAME "Pyramid"
#define UI_PRINTER_COMPANY "FJMSoft"
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_REVERSE_ENCODER 1
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   260
#define NUM_MOTOR_DRIVERS 0
    "editMode": 2,
    "processor": 0,
    "baudrate": 115200,
    "bluetoothSerial": -1,
    "bluetoothBaudrate": 115200,
    "xStepsPerMM": 100,
    "yStepsPerMM": 100,
    "zStepsPerMM": 2560,
    "xInvert": 0,
    "x2Invert": 0,
    "xInvertEnable": 0,
    "eepromMode": 1,
    "yInvert": 0,
    "y2Invert": 0,
    "yInvertEnable": 0,
    "zInvert": 0,
    "z2Invert": 0,
    "z3Invert": 0,
    "z4Invert": 0,
    "zInvertEnable": 0,
    "extruder": [
            "id": 0,
            "heatManager": 3,
            "pidDriveMin": 40,
            "pidDriveMax": 230,
            "pidMax": 255,
            "sensorType": 1,
            "sensorPin": "TEMP_0_PIN",
            "heaterPin": "HEATER_0_PIN",
            "maxFeedrate": 50,
            "startFeedrate": 20,
            "invert": "0",
            "invertEnable": "0",
            "acceleration": 5000,
            "watchPeriod": 1,
            "pidP": 7,
            "pidI": 2,
            "pidD": 40,
            "advanceK": 0,
            "advanceL": 0,
            "waitRetractTemp": 150,
            "waitRetractUnits": 0,
            "waitRetract": 0,
            "stepsPerMM": 370,
            "coolerPin": -1,
            "coolerSpeed": 255,
            "selectCommands": "",
            "deselectCommands": "",
            "xOffset": 0,
            "yOffset": 0,
            "zOffset": 0,
            "xOffsetSteps": 0,
            "yOffsetSteps": 0,
            "zOffsetSteps": 0,
            "stepper": {
                "name": "Extruder 0",
                "step": "ORIG_E0_STEP_PIN",
                "dir": "ORIG_E0_DIR_PIN",
            "advanceBacklashSteps": 0,
            "decoupleTestPeriod": 12,
            "jamPin": -1,
            "jamPullup": "0",
            "mirror": "0",
            "invert2": "0",
            "stepper2": {
            "preheat": 190
    "uiLanguage": 0,
    "uiController": 0,
    "xMinEndstop": 0,
    "yMinEndstop": 2,
    "zMinEndstop": 2,
    "xMaxEndstop": 2,
    "yMaxEndstop": 0,
    "zMaxEndstop": 0,
    "x2MinEndstop": 0,
    "y2MinEndstop": 0,
    "x2MaxEndstop": 0,
    "y2MaxEndstop": 0,
    "motherboard": 33,
    "driveSystem": 0,
    "xMaxSpeed": 300,
    "xHomingSpeed": 40,
    "xTravelAcceleration": 100,
    "xPrintAcceleration": 100,
    "yMaxSpeed": 300,
    "yHomingSpeed": 40,
    "yTravelAcceleration": 100,
    "yPrintAcceleration": 100,
    "zMaxSpeed": 7.5,
    "zHomingSpeed": 2,
    "zTravelAcceleration": 30,
    "zPrintAcceleration": 30,
    "xMotor": {
        "name": "X motor",
        "step": "ORIG_X_STEP_PIN",
        "dir": "ORIG_X_DIR_PIN",
        "enable": "ORIG_X_ENABLE_PIN"
    "yMotor": {
        "name": "Y motor",
        "step": "ORIG_Y_STEP_PIN",
        "dir": "ORIG_Y_DIR_PIN",
        "enable": "ORIG_Y_ENABLE_PIN"
    "zMotor": {
        "name": "Z motor",
        "step": "ORIG_Z_STEP_PIN",
        "dir": "ORIG_Z_DIR_PIN",
        "enable": "ORIG_Z_ENABLE_PIN"
    "enableBacklash": "0",
    "backlashX": 0,
    "backlashY": 0,
    "backlashZ": 0,
    "stepperInactiveTime": 360,
    "maxInactiveTime": 0,
    "xMinPos": 0,
    "yMinPos": 0,
    "zMinPos": 0,
    "xLength": 200,
    "yLength": 200,
    "zLength": 300,
    "alwaysCheckEndstops": "1",
    "disableX": "0",
    "disableY": "0",
    "disableZ": "0",
    "disableE": "0",
    "xHomeDir": "1",
    "yHomeDir": "-1",
    "zHomeDir": "-1",
    "xEndstopBack": 2,
    "yEndstopBack": 2,
    "zEndstopBack": 0,
    "deltaDiagonalRod": 445,
    "deltaAlphaA": 210,
    "deltaAlphaB": 330,
    "deltaAlphaC": 90,
    "deltaDiagonalCorrA": 0,
    "deltaDiagonalCorrB": 0,
    "deltaDiagonalCorrC": 0,
    "deltaMaxRadius": 150,
    "deltaRadiusCorrA": 0,
    "deltaRadiusCorrB": 0,
    "deltaRadiusCorrC": 0,
    "deltaXOffsetSteps": 0,
    "deltaYOffsetSteps": 0,
    "deltaZOffsetSteps": 0,
    "deltaSegmentsPerLine": 20,
    "stepperHighDelay": 0,
    "directionDelay": 0,
    "allowQuadstepping": "1",
    "doubleStepDelay": 0,
    "maxJerk": 20,
    "maxZJerk": 0.3,
    "moveCacheSize": 16,
    "moveCacheLow": 10,
    "lowTicksPerMove": 250000,
    "enablePowerOnStartup": "1",
    "echoOnExecute": "1",
    "sendWaits": "1",
    "ackWithLineNumber": "1",
    "killMethod": 1,
    "useAdvance": "0",
    "useQuadraticAdvance": "0",
    "powerInverting": 0,
    "mirrorX": 0,
    "mirrorXMotor": {
        "name": "Extruder 1",
        "step": "ORIG_E1_STEP_PIN",
        "dir": "ORIG_E1_DIR_PIN",
    "mirrorY": 0,
    "mirrorYMotor": {
    "mirrorZ": "0",
    "mirrorZMotor": {
    "mirrorZ3": "0",
    "mirrorZ3Motor": {
        "name": "Extruder 2",
        "step": "ORIG_E2_STEP_PIN",
        "dir": "ORIG_E2_DIR_PIN",
    "mirrorZ4": "0",
    "mirrorZ4Motor": {
        "name": "Extruder 3",
        "step": "ORIG_E3_STEP_PIN",
        "dir": "ORIG_E3_DIR_PIN",
    "dittoPrinting": "0",
    "featureServos": "1",
    "servo0Pin": 11,
    "servo1Pin": 6,
    "servo2Pin": 5,
    "servo3Pin": 4,
    "featureWatchdog": "1",
    "hasHeatedBed": "1",
    "enableZProbing": "0",
    "extrudeMaxLength": 160,
    "homeOrder": "HOME_ORDER_XYZ",
    "featureController": 11,
    "uiPrinterName": "Pyramid",
    "uiPrinterCompany": "FJMSoft",
    "uiPagesDuration": 4000,
    "uiHeadline": "",
    "uiDisablePageswitch": "1",
    "uiAutoReturnAfter": 30000,
    "featureKeys": "0",
    "uiEncoderSpeed": 2,
    "uiReverseEncoder": "1",
    "uiKeyBouncetime": 10,
    "uiKeyFirstRepeat": 500,
    "uiKeyReduceRepeat": 50,
    "uiKeyMinRepeat": 50,
    "featureBeeper": "1",
    "uiMinHeatedBed": 30,
    "uiMaxHeatedBed": 120,
    "uiMinEtxruderTemp": 170,
    "uiMaxExtruderTemp": 260,
    "uiExtruderFeedrate": 2,
    "maxBedTemperature": 120,
    "bedSensorType": 4,
    "bedSensorPin": "TEMP_1_PIN",
    "bedHeatManager": 0,
    "bedPreheat": 55,
    "bedUpdateInterval": 5000,
    "bedPidDriveMin": 80,
    "bedPidDriveMax": 255,
    "bedPidP": 196,
    "bedPidI": 33,
    "bedPidD": 290,
    "bedPidMax": 255,
    "bedDecoupleTestPeriod": 300,
    "caseLightPin": -1,
    "caseLightDefaultOn": "1",
    "bedSkipIfWithin": 3,
    "gen1T0": 25,
    "gen1R0": 100000,
    "gen1Beta": 4036,
    "gen1MinTemp": -20,
    "gen1MaxTemp": 300,
    "gen1R1": 0,
    "gen1R2": 4700,
    "gen2T0": 25,
    "gen2R0": 100000,
    "gen2Beta": 4036,
    "gen2MinTemp": -20,
    "gen2MaxTemp": 300,
    "gen2R1": 0,
    "gen2R2": 4700,
    "gen3T0": 25,
    "gen3R0": 100000,
    "gen3Beta": 4036,
    "gen3MinTemp": -20,
    "gen3MaxTemp": 300,
    "gen3R1": 0,
    "gen3R2": 4700,
    "userTable0": {
        "r1": 0,
        "r2": 4700,
        "temps": [],
        "numEntries": 0
    "userTable1": {
        "r1": 0,
        "r2": 4700,
        "temps": [],
        "numEntries": 0
    "userTable2": {
        "r1": 0,
        "r2": 4700,
        "temps": [],
        "numEntries": 0
    "tempHysteresis": 0,
    "pidControlRange": 20,
    "skipM109Within": 2,
    "extruderFanCoolTemp": 50,
    "minTemp": 150,
    "maxTemp": 275,
    "minDefectTemp": -10,
    "maxDefectTemp": 290,
    "arcSupport": "1",
    "forceChecksum": "0",
    "sdExtendedDir": "1",
    "featureFanControl": "1",
    "fanPin": "ORIG_FAN_PIN",
    "featureFan2Control": "0",
    "fan2Pin": "ORIG_FAN2_PIN",
    "fanThermoPin": -1,
    "fanThermoMinPWM": 128,
    "fanThermoMaxPWM": 255,
    "fanThermoMinTemp": 45,
    "fanThermoMaxTemp": 60,
    "fanThermoThermistorPin": -1,
    "fanThermoThermistorType": 1,
    "scalePidToMax": 0,
    "zProbePin": -1,
    "zProbeBedDistance": 10,
    "zProbeDisableHeaters": "0",
    "zProbePullup": "0",
    "zProbeOnHigh": "0",
    "zProbeXOffset": 0,
    "zProbeYOffset": 0,
    "zProbeWaitBeforeTest": "0",
    "zProbeSpeed": 2,
    "zProbeXYSpeed": 150,
    "zProbeHeight": 40,
    "zProbeStartScript": "",
    "zProbeFinishedScript": "",
    "featureAutolevel": "0",
    "zProbeX1": 20,
    "zProbeY1": 20,
    "zProbeX2": 160,
    "zProbeY2": 20,
    "zProbeX3": 20,
    "zProbeY3": 160,
    "zProbeSwitchingDistance": 1,
    "zProbeRepetitions": 1,
    "zProbeMedian": "0",
    "zProbeEveryPoint": "",
    "sdSupport": "1",
    "sdCardDetectPin": -1,
    "sdCardDetectInverted": "0",
    "uiStartScreenDelay": 1000,
    "xEndstopBackMove": 5,
    "yEndstopBackMove": 5,
    "zEndstopBackMove": 2,
    "xEndstopRetestFactor": 3,
    "yEndstopRetestFactor": 3,
    "zEndstopRetestFactor": 3,
    "xMinPin": "ORIG_X_MIN_PIN",
    "yMinPin": "ORIG_Y_MIN_PIN",
    "zMinPin": "ORIG_Z_MIN_PIN",
    "xMaxPin": "ORIG_X_MAX_PIN",
    "yMaxPin": "ORIG_Y_MAX_PIN",
    "zMaxPin": "ORIG_Z_MAX_PIN",
    "x2MinPin": -1,
    "y2MinPin": -1,
    "x2MaxPin": -1,
    "y2MaxPin": -1,
    "deltaHomeOnPower": "0",
    "fanBoardPin": -1,
    "heaterPWMSpeed": 0,
    "featureBabystepping": "1",
    "babystepMultiplicator": 1,
    "pdmForHeater": "0",
    "pdmForCooler": "0",
    "psOn": "ORIG_PS_ON_PIN",
    "mixingExtruder": "0",
    "featureAxisComp": "0",
    "axisCompTanXY": 0,
    "axisCompTanXZ": 0,
    "axisCompTanYZ": 0,
    "retractOnPause": 2,
    "pauseStartCommands": "",
    "pauseEndCommands": "",
    "distortionCorrection": "0",
    "distortionCorrectionR": 100,
    "distortionPermanent": "1",
    "distortionEndDegrade": 1,
    "distortionXMin": 10,
    "distortionXMax": 190,
    "distortionYMin": 10,
    "distortionYMax": 190,
    "sdRunOnStop": "",
    "featureRetraction": "1",
    "autoretractEnabled": "0",
    "retractionLength": 3,
    "retractionLongLength": 13,
    "retractionSpeed": 40,
    "retractionZLift": 0,
    "retractionUndoSpeed": 20,
    "filamentChangeXPos": 0,
    "filamentChangeYPos": 0,
    "filamentChangeZAdd": 2,
    "filamentChangeRehome": 1,
    "fanKickstart": 200,
    "servo0StartPos": -1,
    "servo1StartPos": -1,
    "servo2StartPos": -1,
    "servo3StartPos": -1,
    "uiDynamicEncoderSpeed": "1",
    "uiServoControl": 1,
    "killIfSensorDefect": "0",
    "jamSteps": 220,
    "jamSlowdownSteps": 320,
    "jamSlowdownTo": 70,
    "jamErrorSteps": 500,
    "jamMinSteps": 10,
    "jamAction": 1,
    "jamMethod": 1,
    "primaryPort": 0,
    "numMotorDrivers": 0,
    "motorDrivers": [
            "t": "None",
            "s": "",
            "invertDirection": "0",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "invertEndstop": "0",
            "minEndstop": "1",
            "endstopPullup": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
    "manualConfig": "",
    "zHomeMinTemperature": 0,
    "zHomeXPos": 999999,
    "zHomeYPos": 999999,
    "zHomeHeatHeight": 20,
    "zHomeHeatAll": "1",
    "zProbeZOffsetMode": 0,
    "zProbeZOffset": 0,
    "zProbeDelay": 0,
    "uiBedCoating": "1",
    "langEN": "1",
    "langDE": "0",
    "langNL": "0",
    "langPT": "1",
    "langIT": "0",
    "langES": "0",
    "langFI": "0",
    "langSE": "0",
    "langFR": "0",
    "langCZ": "0",
    "langPL": "0",
    "langTR": "0",
    "langRU": "0",
    "accelerationFactorTop": 100,
    "bendingCorrectionA": 0,
    "bendingCorrectionB": 0,
    "bendingCorrectionC": 0,
    "supportLaser": "1",
    "laserPin": 4,
    "laserOnHigh": "1",
    "laserWarmupTime": 0,
    "defaultPrinterMode": 0,
    "laserPwmMax": 255,
    "laserWatt": 5,
    "supportCNC": "1",
    "cncWaitOnEnable": 300,
    "cncWaitOnDisable": 0,
    "cncEnablePin": -1,
    "cncEnableWith": "1",
    "cncDirectionPin": -1,
    "cncDirectionCW": "1",
    "cncPwmMax": 255,
    "cncRpmMax": 8000,
    "cncSafeZ": 150,
    "startupGCode": "",
    "jsonOutput": "0",
    "bedLevelingMethod": 0,
    "bedCorrectionMethod": 0,
    "bedLevelingGridSize": 5,
    "bedLevelingRepetitions": 5,
    "bedMotor1X": 0,
    "bedMotor1Y": 0,
    "bedMotor2X": 200,
    "bedMotor2Y": 0,
    "bedMotor3X": 100,
    "bedMotor3Y": 200,
    "zProbeRequiresHeating": "0",
    "zProbeMinTemperature": 150,
    "adcKeypadPin": -1,
    "sharedExtruderHeater": "0",
    "extruderSwitchXYSpeed": 100,
    "dualXAxis": "0",
    "boardFanSpeed": 255,
    "keepAliveInterval": 2000,
    "moveXWhenHomed": "0",
    "moveYWhenHomed": "0",
    "moveZWhenHomed": "0",
    "preheatTime": 30000,
    "multiZEndstopHoming": "0",
    "z2MinMaxPin": -1,
    "z2MinMaxEndstop": 0,
    "extruderIsZProbe": "0",
    "boardFanMinSpeed": 0,
    "doorPin": -1,
    "doorEndstop": 1,
    "zhomePreRaise": 0,
    "zhomePreRaiseDistance": 10,
    "dualXResolution": "0",
    "x2axisStepsPerMM": 100,
    "coolerPWMSpeed": 0,
    "maxFanPWM": 255,
    "raiseZOnToolchange": 0,
    "distortionLimitTo": 2,
    "automaticPowerup": 0,
    "hasTMC2130": "0",
    "TMC2130Sensorless": "0",
    "TMC2130Steathchop": "1",
    "TMC2130Interpolate256": "1",
    "TMC2130StallguardSensitivity": 0,
    "TMC2130PWMAmpl": 255,
    "TMC2130PWMGrad": 1,
    "TMC2130PWMAutoscale": "1",
    "TMC2130PWMFreq": 2,
    "TMC2130CSX": -1,
    "TMC2130CSY": -1,
    "TMC2130CSZ": -1,
    "TMC2130CSE0": -1,
    "TMC2130CSE1": -1,
    "TMC2130CSE2": -1,
    "TMC2130CurrentX": 1000,
    "TMC2130CurrentY": 1000,
    "TMC2130CurrentZ": 1000,
    "TMC2130CurrentE0": 1000,
    "TMC2130CurrentE1": 1000,
    "TMC2130CurrentE2": 1000,
    "TMC2130CoolstepTresholdX": 300,
    "TMC2130CoolstepTresholdY": 300,
    "TMC2130CoolstepTresholdZ": 300,
    "microstepX": 16,
    "microstepY": 16,
    "microstepZ": 16,
    "microstepE0": 16,
    "microstepE1": 16,
    "microstepE2": 16,
    "parkPosX": 0,
    "parkPosY": 0,
    "parkPosZ": 0,
    "emergencyParser": -1,
    "hostRescue": "1",
    "MAX31855SwCS": -1,
    "MAX31855SwCLK": -1,
    "tempGain": "0",
    "hasMAX6675": false,
    "hasMAX31855": false,
    "hasGeneric1": false,
    "hasGeneric2": false,
    "hasGeneric3": false,
    "hasUser0": false,
    "hasUser1": false,
    "hasUser2": false,
    "numExtruder": 1,
    "version": 100.4,
    "primaryPortName": "",
    "hasMAX31855SW": false
  • Pin 0/1 is the serial connection.
    Laser is only enabled at G1 moves for safety.
    In FFF mode it will not be used if you do not have it connected to something like fan. M42 might also enable it but then you need it also to disable it.
    in driver.h you see the laser driver. It gets power levels 0-255 but maps only to on/off. There you can add control for a pwm output. But you are not allowed to use a time used for firmware. So timers 0-2 are surely off limits here. For the others you can use the analogWrite of arduino to set the power instead. Just look which pin using time 3-5 is available.
  • edited March 2019
    Thanks for your answer.
    Ok, I have understood about the pin, I will choose another one.
    About the PWM output, I'm really needing it, I cant focus this laser, it is so strong I cant even look it, so I thought about using a PWM output to get it smoother and focus.
    There isnt a simpler solution for this?
    There isnt a ready PWM output?
    If I activate the laser with M42 and put the value in S parameter can I get this result?
    PS: I'm thinking about a tool changer part for my printer, so I can quick change extruder for laser, I will have the heater pins available, there is a way to turn it on to power the laser?
    Thank you again.
  • Don't think you can use heater pins also as laser pins. They are controlled by temperature loop already.
    You can check the datasheet of mega2560 and see which pin uses which timer. As said timer 0-2 are reserved for firmware internal use. all you need to do is in Driver.h change the digital write with an analog write. Not sure if pwm signal is fast enough but surely faster than 15hz of heater pwms.
  • I dont have knowledge yet to deal with the Arduino code, I will need hard help or a ready solution, but still cant find by now, yesterday I made a deep search, but no success.
    I think you missed th heater part... I want to use the heater pin as laser POWER, not the TTL.
    Just to put heater output in high state.
  • No, heater i snot good for that. You want 100% output for main power. For my laser I used a fan output for enabling main power. You can use second fan for this which is not controlled by slicers.
    Laser is set in Drivers.cpp in this function
    void LaserDriver::changeIntensity(secondspeed_t newIntensity) {
    #if defined(DOOR_PIN) && DOOR_PIN > -1
    if (Printer::isDoorOpen()) {
    newIntensity = 0; // force laser off if door is open
    if (EVENT_SET_LASER(newIntensity)) {
    // Default implementation
    #if LASER_PIN > -1
    WRITE(LASER_PIN, (LASER_ON_HIGH ? newIntensity > 199 : newIntensity < 200));
    intens = newIntensity; // for "Transfer" Status Page
    make sthe digital write. Using ardiono PWM function it would change to
    analogWrite(LASER_PIN, newIntensity);
    that is all needed.
    Time mapping is
    - timer0 = Pins 4, 13
    - timer1 = Pins 11,12
    - timer2 = Pins 9, 10
    - timer3  = Pin 2, 3, 5
    - timer4 = Pin 6, 7, 8
    - timer5 = Pin 44, 45, 46
    But as said timer 0-2 are forbidden, so check the remaining pins.
  • edited April 2019
    Wow! Very nice friend! Thank you very much!
    Looks like pin 44 is the best fit for me.
    I have more questions.
    1. There is really no way to keep the laser on with the machine stopped? I need this to focus the laser.
    2. There is a way change the PWM frequency?
    Thank you very much again.
    PS: Maybe think about putting this code as default.
  • Arduino lib has no way as far as I know. You can google for an other solution that optimizes the chip settings for different frequencies. Not sure which frequency it uses.
    No laser will be off, but as a solution you can add a slow move instead after having set a low intensity
  • edited April 2019
    Found this:
    https://forum.arduino.cc/index.php?topic=54782.0
                 TIMER 5
    Value                             Divisor                      Frequency
    0x01                                  1                                ? hz
    0x02                                  8                                ? hz
    0x03                                 64                                ? hz      // default
    0x04                                 128                               ? hz
    0x05                                 1024                              ? hz
    Code:                 TCCR5B = (TCCR5B & 0xF8) | value ;
    So, looks like there is a frequency setting.
    Says to put this in the code (below), but where should I put this?
    void setup () {
  • You need to put it in the setup yes, so it is initialized. Limit pwm frequency with 8 bit resolution is 16000000/256 = 62500 hz, so is quite good with divisor 1. Not sure how arduino selects the divisor. But you also need to enable timer and set value using registers. Chances are good that arduino will otherwise overwrite with it's own divisor. But the direction is correct. Init and set pwm = 0 in setup and in the driver only set pwm value. That is all required.
  • void setup()
        Printer::setup();
    Should I put here?
    (Repetier.ino)
  • No in Printer.cpp void Printer::setup() { after
    HAL::hwSetup();
    or if you use custom events you can also put it into
    EVENT_INITIALIZE_EARLY variable.
    #if LASER_PIN > -1
    that is all needed.
    Time mapping is
    Hey friend, There is a way to put this in the events?
    So I dont need to modify every time I update the firmware.
    Thank you.
  • EVENT_SET_LASER is the event. If it return false it will not override what you do. Default is just to return true so the default handling is used.
  • Ok, but what should I put in the events to have the pwm output?
  • A call to a function in your custom events returning true and sending the wanted intensity. More or less it contains the same you would put into the if condition else, so analogWrite(val); or if you do it with another chip the transmit command to tell it new pwm value.
    BTW: If you use a due based board you coudl use V2 firmware (dev2 tree on github). There laser has already hardware pwm support, gamma and speed correction.
  • I dont know how to code this by myself, but thank you anyway.
    My board is the Mega.
  • Mega support will come in V2 then it should be easier.
