Virtual extruders bug
When I configure repetier to use extruders 6-16 in a single print, the g-code generated by curaengine uses extruders 0-10 and not 6-16
I load 21 different STL files and drag them all to the same object. I then select extruders for each object, in the range 6-16
Generated g-code contains commands T0 -> T10
