G33 Begin height question
After fiddeling around and doing leveling stuff i changed the Z-Max probe bed distance in Eeprom.
G32 started a the desired height, in my case 3 mm (i know its close but the z-probe speed is slow)
after that i started G33 and saw that the referenced height was 20 mm, it took more than 1,5 minutes to do 1 probe point.
Because i had some time to spend i was looking in the Firmware if this height was somehow fixt.
i stumbled on these lines
now if i read it correctly the refence z height = z probebeddistance (3mm in my case?) + z probe height, unless lower than 0 then add 0 (in my case 1,377mm), then the last value is 20mm
in configuration.h ZHOME_HEAT_HEIGHT was mentioned and had the value 20, because in the rest of firmware this value is used for allot of stuff i didn't want to fiddle with it especially that my printer is running good right now
hope somebody can enlighten me, that wil be great
bool Distortion::measure(void) {
fast8_t ix, iy;
disable(false);
Printer::prepareForProbing();
float z = RMath::max(EEPROM::zProbeBedDistance() + (EEPROM::zProbeHeight() > 0 ? EEPROM::zProbeHeight() : 0), static_cast<float>(ZHOME_HEAT_HEIGHT)); //EEPROM::zProbeBedDistance() + (EEPROM::zProbeHeight() > 0 ? EEPROM::zProbeHeight() : 0);
Com::printFLN(PSTR("Reference Z for measurement:"), z, 3);
updateDerived(); now if i read it correctly the refence z height = z probebeddistance (3mm in my case?) + z probe height, unless lower than 0 then add 0 (in my case 1,377mm), then the last value is 20mm
