Z probe type LJ12A3-4-Z/BX onto RADDS board
Hey Guys,
I have a Z-Probe of type: LJ12A3-4-Z/BX (12V), and I want to install it onto my RADDS board.
I figured out I need to add a resistor divider with 10KΩ and 3.3KΩ in order not to fry my board.
What I didn't figure out yet is what pins I need to use for my signal pin;
Do I need to use Z_min endstop or do I need to use Servo PMW3?
The  12VDC and GND I need to install onto the PSU or maybe I could fake extruder fan 2 which I am not using for fans.
I also want to use the autolevel function so I don't need to have my bed level spot on which is kinda cool.
So do I need to change my mechanical endstop to Z_max instead of Z_min where it is installed now (or am I wrong with this)?
I know lots of questions but youtube and lots of internet information is kinda all about Ramps and lots of marlin
Thanks in common.
Cheers,
Dennis
  • z min endstop switch makes only sense with a leveled bed. If you want to allow it not leveled you need to remove it.
    You have 2 options. Use z probe as z min pin as well or use z max homing. z max homing has some benefits but homing takes a bit longer.
    Z probe just needs a digital input pin. You can use any free pin, just set the right pin number. So y_max is also an option. If you use it as z min probe as well set z min endstop to same pin.
    Don't know the sensor type, so why do you think you need a servo pin?
    So when I want to use auto bed level I need to connect to Z_max ? So how does that work exactly, when I disconnect my Z_min endstop and connect a Z_max probe using the endstop signal pin?
    About the servo pin thing: http://www.akeric.com/blog/?p=4062
    There is where I found it; Not many people use RADDS so this is kind of the only guy giving explanation about it.
  • Ok, no idea why he used a servo pin for it, but has nothing to do with servo. As I said pins may have names but get function you assign, so any free pin works. Only important is that it is configured as input and you do not exceed 3.3V.
    So you want to go with z probe only. Just unplug z min endstop and put your z probe signal pin to z min pin. Select pullup no and check if signal is ok using M114. If it is H when not triggered invert endstop.
    Assign z probe also the z min pin, so firmware knows about the special condition. Also set pullup/signal same as end stop so M114 signals it right.
    As a first test run G30 with a metal holding close to sensor to stop before you reach bed. That way you have time enough to reset printer if it does not stop. Do the same for z homing. When you know it works you can let it go down to bed for testing.
    So this config should do the trick:
    #define ENDSTOP_PULLUP_X_MIN false  // pullup false
    #define FEATURE_Z_PROBE 1  //Set to enabled
    #define Z_PROBE_PIN 18  // according to pins.h #define ORIG_Z_MIN_PIN      18
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 40
    #define FEATURE_AUTOLEVEL 1
    Just changed my original Firmware, pullup false, pin changed and autolevel on.
  • Yes, looks good.
  • #define Z_PROBE_X_OFFSET 0
    These need setting according to the offset distance of probe to nozzle
    I know, but thanks for the reminder. I still am doing the wiring and proper testing with the voltage divider to not fry my main board.
    Wiring worked, the offset X and Y .. are those calculated from extruder 0 or 1 or do I need to define both?
    Also G30 p0 gives me error: G30 z-probe failed. How could I fix that?
  • You define where 0,0 is. With 2 extruders it is normally the left extruder. Offsets are then relative to that. Only for deltas you MUST take the center of the carriage as origin.
  • That worked. So when disabling the hardware zmin endstop as the guide says in the probe manual on the website; it won't stop anymore when it reached the bottom. Why is that?
  • It also says you have to set z min end stop to the z probe sensor! as I said at 5 march. For homing it will use still z min but it must be wired to the probe and not to the z min endstop. That way we know at which position we hit the bed.
  • I don't know what made it work but I think the software endstop did the trick because it isn't crashing in the bed. All works now! :smiley:
