Kossel Delta Home All Problem
Hi, I sent the printer home. The printer is receiving this shape. I haven't solved the problem. I'd appreciate it if you could help. Thanks
  • Does the 3rd not move or stop early?
    If it does not move check endstops with M119 if they trigger correctly.
    If it stops early it is normally cross talk to end stop causing it to stop. Then twist sensor cable and make sure it has some distance to extruder motor cables or what else comes close to them.
    Do they all start moving same time? If not you have not selected delta system as printer type.
