Conect with Ultimaker 3
Hello everyone,
I would like to know if a can connect via the repetier server with an Ultimaker 3 extended Printer.
I searched and did not find something similar (except one post in the forum, which did not work ).
Thank you in advance.
Kostas
Easiest is to try your self. The free version is all you need for testing. If free can do, the pro does it as well a sit is the same software:-)
I will test it.
Moreover can i connect the prusa i3 MK3 definetly with repetier server?? Right?
And if i am connected with the prusa i3 MK3, so i will be with the pro version?
Thank you again !
