New printer Creality CR10S PRO : connection ok but manual control no ok !!
thsths
edited February 2019 in General
CR10 S PRO and REPETIER HOST , the printer is well connected to Repetier (button "connec t", logs received...) but no functions are operational ??? (move the axis, home etc..) and none gcodes sent works..  An idea? Thanks
  • What does the log show? I'm aware of a problem with wrong format of temperature report so you will not see temperatures, but beside that it should work. Do you see communication in log? Maybe you just have set wrong baud rate, which is the typical reason that nothing works.
  • thsths
    If i set baud rate :115200  the machine is connected and I have logs in the bottom window of Repetier BUT no functions are operational and no gcode are sended …(it seems that Repetier-Host receive the logs but it can't send? )  If I set 250000 the printer is not connected … Where can I send the "Logs" on the Forum?
  • Just copy/paste the log to text. Since you say you can not talk it can't be so much. Make sue filters like ack/commands are not enabled so we see all communication.
  • Here are the "logs" at the printer connection. I quickly disconnected so that there are not too many "logs" because I have the impression that it turns in loop, certainly due to errors ??
    17:20:23.432 : Printer reset detected - initalizing
    17:20:23.432 : start
    17:20:23.432 : echo: External Reset
    17:20:23.432 : Marlin Ver 1.60.3
    17:20:23.541 : echo: Last Updated: 2017-10-10 12:00 | Author: CR-10S Pro
    17:20:23.541 : echo:Compiled: Dec  6 2018
    17:20:23.541 : echo: Free Memory: 1454  PlannerBufferBytes: 1232
    17:20:23.541 : echo:V41 stored settings retrieved (526 bytes; crc 17960)
    17:20:23.541 : echo:  G21    ; Units in mm
    17:20:23.541 : echo:  M149 C ; Units in Celsius
    17:20:23.541 : echo:Filament settings: Disabled
    17:20:23.541 : echo:  M200 D1.75
    17:20:23.541 : echo:  M200 D0
    17:20:23.541 : echo:Steps per unit:
    17:20:23.541 : echo:  M92 X80.00 Y80.00 Z400.00 E140.00
    17:20:23.541 : echo:Maximum feedrates (units/s):
    17:20:23.541 : echo:  M203 X300.00 Y300.00 Z5.00 E25.00
    17:20:23.541 : echo:Maximum Acceleration (units/s2):
    17:20:23.541 : echo:  M201 X500 Y500 Z100 E5000
    17:20:23.541 : echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
    17:20:23.541 : echo:  M204 P500.00 R1000.00 T500.00
    17:20:23.541 : echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
    17:20:23.541 : echo:  M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.40 E5.00
    17:20:23.541 : echo:Home offset:
    17:20:23.541 : echo:  M206 X0.00 Y0.00 Z0.00
    17:20:23.541 : echo:Auto Bed Leveling:
    17:20:23.541 : echo:  M420 S0 Z0.00
    17:20:23.541 : echo:PID settings:
    17:20:23.541 : echo:  M301 P20.84 I1.96 D55.47
    17:20:23.541 : echo:Z-Probe Offset (mm):
    17:20:23.541 : echo:  M851 Z0.00
    17:20:23.838 : echo:SD card ok
    17:20:23.838 : Init power off infomation.
    17:20:23.838 : size:
    17:20:23.838 : 593
    17:20:23.932 : init valid:
    17:20:23.932 : 0
    17:20:23.932 : 0
    17:20:23.932 : echo:V41 stored settings retrieved (526 bytes; crc 17960)
    17:20:23.932 : echo:  G21    ; Units in mm
    17:20:23.932 : echo:  M149 C ; Units in Celsius
    17:20:23.932 : echo:Filament settings: Disabled
    17:20:23.932 : echo:  M200 D1.75
    17:20:23.932 : echo:  M200 D0
    17:20:23.932 : echo:Steps per unit:
    17:20:23.932 : echo:  M92 X80.00 Y80.00 Z400.00 E140.00
    17:20:23.932 : echo:Maximum feedrates (units/s):
    17:20:23.932 : echo:  M203 X300.00 Y300.00 Z5.00 E25.00
    17:20:23.932 : echo:Maximum Acceleration (units/s2):
    17:20:23.932 : echo:  M201 X500 Y500 Z100 E5000
    17:20:23.932 : echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
    17:20:23.932 : echo:  M204 P500.00 R1000.00 T500.00
    17:20:23.932 : echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
    17:20:23.932 : echo:  M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.40 E5.00
    17:20:23.932 : echo:Home offset:
    17:20:23.932 : echo:  M206 X0.00 Y0.00 Z0.00
    17:20:23.932 : echo:Auto Bed Leveling:
    17:20:23.932 : echo:  M420 S0 Z0.00
    17:20:23.932 : echo:PID settings:
    17:20:23.932 : echo:  M301 P20.84 I1.96 D55.47
    17:20:23.932 : echo:Z-Probe Offset (mm):
    17:20:23.932 : echo:  M851 Z0.00
    17:20:23.932 : ***Initing card is OK***
    17:20:23.948 : echo:SD card ok
    17:20:24.151 : ===Initing RTS has finished===
    17:20:24.229 : FIRMWARE_NAME:Marlin Ver 1.60.3 (Creality3D) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:www.cxsw3d.com EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
    17:20:24.229 : Cap:EEPROM:1
    17:20:24.229 : Cap:AUTOREPORT_TEMP:1
    17:20:24.229 : Cap:PROGRESS:0
    17:20:24.229 : Cap:PRINT_JOB:1
    17:20:24.229 : Cap:AUTOLEVEL:1
    17:20:24.229 : Cap:Z_PROBE:1
    17:20:24.229 : Cap:LEVELING_DATA:1
    17:20:24.229 : Cap:SOFTWARE_POWER:0
    17:20:24.229 : Cap:TOGGLE_LIGHTS:0
    17:20:24.229 : Cap:CASE_LIGHT_BRIGHTNESS:0
    17:20:24.229 : Cap:EMERGENCY_PARSER:0
    17:20:24.291 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
    17:20:24.323 : echo:DEBUG:INFO,ERRORS
    17:20:24.354 : echo:Active Extruder: 0
    17:20:24.385 : Begin file list
    17:20:24.385 : TEST-D~1.GCO 16902719
    17:20:24.448 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:24.745 : XYZCAL~1.GCO 301443
    17:20:24.760 : End file list
    17:20:24.791 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:24.791 : Resend: 1
    17:20:24.823 : Begin file list
    17:20:24.823 : TEST-D~1.GCO 16902719
    17:20:24.885 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:25.167 : XYZCAL~1.GCO 301443
    17:20:25.167 : End file list
    17:20:25.229 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:25.229 : Resend: 1
    17:20:25.245 : Begin file list
    17:20:25.245 : TEST-D~1.GCO 16902719
    17:20:25.291 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:25.573 : XYZCAL~1.GCO 301443
    17:20:25.573 : End file list
    17:20:25.620 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:25.620 : Resend: 1
    17:20:25.682 : FIRMWARE_NAME:Marlin Ver 1.60.3 (Creality3D) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:www.cxsw3d.com EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
    17:20:25.682 : Cap:EEPROM:1
    17:20:25.682 : Cap:AUTOREPORT_TEMP:1
    17:20:25.682 : Cap:PROGRESS:0
    17:20:25.682 : Cap:PRINT_JOB:1
    17:20:25.682 : Cap:AUTOLEVEL:1
    17:20:25.682 : Cap:Z_PROBE:1
    17:20:25.682 : Cap:LEVELING_DATA:1
    17:20:25.682 : Cap:SOFTWARE_POWER:0
    17:20:25.682 : Cap:TOGGLE_LIGHTS:0
    17:20:25.682 : Cap:CASE_LIGHT_BRIGHTNESS:0
    17:20:25.682 : Cap:EMERGENCY_PARSER:0
    17:20:25.776 : FIRMWARE_NAME:Marlin Ver 1.60.3 (Creality3D) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:www.cxsw3d.com EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
    17:20:25.776 : Cap:EEPROM:1
    17:20:25.776 : Cap:AUTOREPORT_TEMP:1
    17:20:25.776 : Cap:PROGRESS:0
    17:20:25.776 : Cap:PRINT_JOB:1
    17:20:25.776 : Cap:AUTOLEVEL:1
    17:20:25.776 : Cap:Z_PROBE:1
    17:20:25.776 : Cap:LEVELING_DATA:1
    17:20:25.776 : Cap:SOFTWARE_POWER:0
    17:20:25.776 : Cap:TOGGLE_LIGHTS:0
    17:20:25.776 : Cap:CASE_LIGHT_BRIGHTNESS:0
    17:20:25.776 : Cap:EMERGENCY_PARSER:0
    17:20:25.838 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
    17:20:25.870 : echo:DEBUG:INFO,ERRORS
    17:20:25.901 : echo:Active Extruder: 0
    17:20:25.948 : Begin file list
    17:20:25.948 : TEST-D~1.GCO 16902719
    17:20:26.010 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:26.307 : XYZCAL~1.GCO 301443
    17:20:26.307 : End file list
    17:20:26.338 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:26.338 : Resend: 1
    17:20:26.370 : Begin file list
    17:20:26.370 : TEST-D~1.GCO 16902719
    17:20:26.448 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:26.729 : XYZCAL~1.GCO 301443
    17:20:26.729 : End file list
    17:20:26.776 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:26.776 : Resend: 1
    17:20:26.792 : Begin file list
    17:20:26.792 : TEST-D~1.GCO 16902719
    17:20:26.838 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:27.120 : XYZCAL~1.GCO 301443
    17:20:27.120 : End file list
    17:20:27.167 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:27.167 : Resend: 1
    17:20:27.292 : FIRMWARE_NAME:Marlin Ver 1.60.3 (Creality3D) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:www.cxsw3d.com EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
    17:20:27.292 : Cap:EEPROM:1
    17:20:27.292 : Cap:AUTOREPORT_TEMP:1
    17:20:27.292 : Cap:PROGRESS:0
    17:20:27.292 : Cap:PRINT_JOB:1
    17:20:27.292 : Cap:AUTOLEVEL:1
    17:20:27.292 : Cap:Z_PROBE:1
    17:20:27.292 : Cap:LEVELING_DATA:1
    17:20:27.292 : Cap:SOFTWARE_POWER:0
    17:20:27.292 : Cap:TOGGLE_LIGHTS:0
    17:20:27.292 : Cap:CASE_LIGHT_BRIGHTNESS:0
    17:20:27.292 : Cap:EMERGENCY_PARSER:0
    17:20:27.354 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
    17:20:27.385 : echo:DEBUG:INFO,ERRORS
    17:20:27.432 : echo:Active Extruder: 0
    17:20:27.464 : Begin file list
    17:20:27.464 : TEST-D~1.GCO 16902719
    17:20:27.526 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:27.807 : XYZCAL~1.GCO 301443
    17:20:27.807 : End file list
    17:20:27.854 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:27.854 : Resend: 1
    17:20:27.885 : Begin file list
    17:20:27.885 : TEST-D~1.GCO 16902719
    17:20:27.948 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:28.245 : XYZCAL~1.GCO 301443
    17:20:28.245 : End file list
    17:20:28.292 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:28.292 : Resend: 1
    17:20:28.307 : Begin file list
    17:20:28.307 : TEST-D~1.GCO 16902719
    17:20:28.354 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:28.636 : XYZCAL~1.GCO 301443
    17:20:28.636 : End file list
    17:20:28.682 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:28.682 : Resend: 1
    17:20:28.745 : FIRMWARE_NAME:Marlin Ver 1.60.3 (Creality3D) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:www.cxsw3d.com EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
    17:20:28.745 : Cap:EEPROM:1
    17:20:28.760 : Cap:AUTOREPORT_TEMP:1
    17:20:28.760 : Cap:PROGRESS:0
    17:20:28.760 : Cap:PRINT_JOB:1
    17:20:28.760 : Cap:AUTOLEVEL:1
    17:20:28.760 : Cap:Z_PROBE:1
    17:20:28.760 : Cap:LEVELING_DATA:1
    17:20:28.760 : Cap:SOFTWARE_POWER:0
    17:20:28.760 : Cap:TOGGLE_LIGHTS:0
    17:20:28.760 : Cap:CASE_LIGHT_BRIGHTNESS:0
    17:20:28.760 : Cap:EMERGENCY_PARSER:0
    17:20:28.854 : FIRMWARE_NAME:Marlin Ver 1.60.3 (Creality3D) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:www.cxsw3d.com EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
    17:20:28.854 : Cap:EEPROM:1
    17:20:28.854 : Cap:AUTOREPORT_TEMP:1
    17:20:28.854 : Cap:PROGRESS:0
    17:20:28.854 : Cap:PRINT_JOB:1
    17:20:28.854 : Cap:AUTOLEVEL:1
    17:20:28.854 : Cap:Z_PROBE:1
    17:20:28.854 : Cap:LEVELING_DATA:1
    17:20:28.854 : Cap:SOFTWARE_POWER:0
    17:20:28.854 : Cap:TOGGLE_LIGHTS:0
    17:20:28.854 : Cap:CASE_LIGHT_BRIGHTNESS:0
    17:20:28.854 : Cap:EMERGENCY_PARSER:0
    17:20:28.917 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
    17:20:28.948 : echo:DEBUG:INFO,ERRORS
    17:20:28.979 : echo:Active Extruder: 0
    17:20:29.011 : Begin file list
    17:20:29.011 : TEST-D~1.GCO 16902719
    17:20:29.073 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:29.370 : XYZCAL~1.GCO 301443
    17:20:29.370 : End file list
    17:20:29.417 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:29.417 : Resend: 1
    17:20:29.448 : Begin file list
    17:20:29.448 : TEST-D~1.GCO 16902719
    17:20:29.511 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:29.792 : XYZCAL~1.GCO 301443
    17:20:29.792 : End file list
    17:20:29.839 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:29.839 : Resend: 1
    17:20:29.870 : Begin file list
    17:20:29.870 : TEST-D~1.GCO 16902719
    17:20:29.901 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:30.198 : XYZCAL~1.GCO 301443
    17:20:30.198 : End file list
    17:20:30.245 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:30.245 : Resend: 1
    17:20:30.308 : FIRMWARE_NAME:Marlin Ver 1.60.3 (Creality3D) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:www.cxsw3d.com EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
    17:20:30.308 : Cap:EEPROM:1
    17:20:30.308 : Cap:AUTOREPORT_TEMP:1
    17:20:30.308 : Cap:PROGRESS:0
    17:20:30.308 : Cap:PRINT_JOB:1
    17:20:30.308 : Cap:AUTOLEVEL:1
    17:20:30.308 : Cap:Z_PROBE:1
    17:20:30.308 : Cap:LEVELING_DATA:1
    17:20:30.308 : Cap:SOFTWARE_POWER:0
    17:20:30.308 : Cap:TOGGLE_LIGHTS:0
    17:20:30.308 : Cap:CASE_LIGHT_BRIGHTNESS:0
    17:20:30.308 : Cap:EMERGENCY_PARSER:0
    17:20:30.401 : FIRMWARE_NAME:Marlin Ver 1.60.3 (Creality3D) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:www.cxsw3d.com EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
    17:20:30.401 : Cap:EEPROM:1
    17:20:30.401 : Cap:AUTOREPORT_TEMP:1
    17:20:30.401 : Cap:PROGRESS:0
    17:20:30.401 : Cap:PRINT_JOB:1
    17:20:30.401 : Cap:AUTOLEVEL:1
    17:20:30.401 : Cap:Z_PROBE:1
    17:20:30.401 : Cap:LEVELING_DATA:1
    17:20:30.401 : Cap:SOFTWARE_POWER:0
    17:20:30.401 : Cap:TOGGLE_LIGHTS:0
    17:20:30.401 : Cap:CASE_LIGHT_BRIGHTNESS:0
    17:20:30.401 : Cap:EMERGENCY_PARSER:0
    17:20:30.464 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
    17:20:30.495 : echo:DEBUG:INFO,ERRORS
    17:20:30.526 : echo:Active Extruder: 0
    17:20:30.558 : Begin file list
    17:20:30.558 : TEST-D~1.GCO 16902719
    17:20:30.620 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:30.933 : XYZCAL~1.GCO 301443
    17:20:30.933 : End file list
    17:20:30.964 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:30.964 : Resend: 1
    17:20:30.995 : Begin file list
    17:20:30.995 : TEST-D~1.GCO 16902719
    17:20:31.058 : /DATA/MODEL/TEST/TEST-D~1.GCO 16902701
    17:20:31.354 : XYZCAL~1.GCO 301443
    17:20:31.354 : End file list
    17:20:31.386 : Error:Line Number is not Last Line Number+1, Last Line: 0
    17:20:31.386 : Resend: 1
    17:20:31.417 : Begin file list
  • Your log has filtered ACK/commands so hard to see what is going on. Looks a bit like it repeats sending M115 also that is not line 1.
    is strange. In Printer Settings->Connection you can change RTS handling. You can try different values there and see if they have some influence on what happens. Some boards use it for some signals and then wrong state might hurt. Normally we toggle it for reset along with DTR signal line.
  • Hi, ok I try it and if it's still the same thing, I'll copy the logs here without the filters   Thank you...
  • Hello i have the same issue.
    thes theme ends without a result.
    Is there a possibility to fixe that issue ??
  • What does you complete log look like - including ack and commands!
