Repetier on Duet Wifi powering a Sparkcube v1.1 XL with MABL, FTS and Motor Endstops?
The title ist nearly self explaining. I´d like to build a Sparkcube v1.1 XL but I haven´t settled on the electronics. RADDS seems to have issues with PT100 sensors or at least it might be more soldering than i´d like to. Duet Wifi seems a good choice but i´m not sure if it would work with RepRapFirmware or Repetier. I hope someone can enlighten me. Thanks.
But I like the drivers so might try to add it sometime to V2 firmware. But I surely need to check in more detail if I can get it running. I never paid much extension since it came with RepRapFirmware from the board designers so for me it was a complete package that was to some points incompatible, also most things can be fixed easily.
Anyhow if you want that board I'd use RepRapFirmware. If you need Repetier-Firmware start with RADDS. One PT100 sensor on radds is no problem. More may be a problem since analog inputs are not available as free pins. I think one of the driver sockets has 3 more that can be used if you do not use all driver sockets.
