Settings of REPETIER
Dear Friends
Thanks for your help! Now I have a new question:
When I connect the printer (Geeetech i3C) to the PC, I can let filament leak in hand mode at both nozzles. The filament, however, runs very thin.
When printing, just as little filament comes out of the nozzles. But that is not enough!
How or where can I increase the leaking amount of filament?
klausi
  • Very much depends where you set it wrong as there are several stages
    Firmware:
    - Steps per mm for extruder
    Server:
    - Flow multiplier
    Slicer:
    - Flow multiplier
    They all get multiplied but normally it is extruder steps per mm not set correct. All others start with reasonable values.
