Setting different E-Steps when using Ditto mode
Dear community
I want to use the ditto-mode to print two parts at once with my two extruders.
The problem I currently have is that one extruders has slightly more steps/mm than the other one (about 4%). I think the reason might be a difference between the diameter of the two extruder gears.
I´ve set the E-steps of the each extruder correctly, but in ditto-mode, both extruders are using the E-steps of the first extruder, so that the second extruders extrudes too much material.
Is there an option to modify the ditto mode so that both extruders keep using their individual E-steps?
Thanks in advance
Legion 23
