No voltage output on D10 pin while G1/G2/G3 command in laser mode
I use Arduino Mega 2560 and Ramps 1.4
I use Repetier-Firmware configuration tool to set firmware on my DIY-SLS-3D printer. It works well with motor control but when it comes to laser:
I have no voltage output on D10 while I use G1/G2/G3 code, so setting laser power has no influence
I use:
G452 //set firmware to laser mode
M3 S150 //set laser power for example to 150
G1 X100 //it only moves to X100 but laser dont work while this.
Can anyone help me?
Also here is URL for the project I've followed
https://www.instructables.com/id/DIY-SLS-3D-Printer/
  • edited January 2019
    PWM for laser is not implemented in Firmware, so values lower than 200 are interpreted as Laser OFF and values >=200
    are interpreted as Laser ON.
    There are several Threads here in Forum regarding Lasers.
    If you want PWM for Laser you have to write your own Driver
  • Well, i tried set M3 S0, M3 S50, .... , M3 S255 and i can't see any difference, laser is still on no matter I move X/Y axis or not, always on.
    G-code M5 (spindle off) doesn't work to.
    I guess it is a problem with voltage output on D10 pin but maybe i i'm wrong? How does it even work?
    so may be you should check your wiring and for tests use a simple led, not the laser.
    just for safety reasons
    BTW Lasermode is set By M452,  not by G452
  • Of course I don't do my tests on laser since I've noticed that it doesn't work correctly.
    I measured voltage on different pins (D10, D9, D8, servos pins) searching for some laser stering signal during G1 X100 command, but without any possitive effect.
    On my repeatier host I can see that machine understand G-code correctly, It is in laser mode, it changes laser power with M3 S255 command. Everything looks good, but the laser output (D10 on ramps, used for extruder heater) always show 0V.
    I tried to use different pins in ramps, for example D8, D9 or D11 (servos pins). In laser mode it always shows 0V.
    I download standard FDM Repetier-software to check if its not a hardware problem (with RAMPS 1.4 or Arduino) and it's work well, for example I see 12V on D9 output and it changes when i change fan power.
    you cannot double use pins.  if it´s used for extruder heater in fdm mode you cannot use that pin for laser in laser mode
  • I mean it is usually used for extruder heater on Ramps.
    In laser mode I use it only for laser output.
  • you should share your configuration.h so we can see whats going on
    Here is my configuration.h file:
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       as you expect.
    #define NUM_EXTRUDER 0
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 1
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 80
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 0
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    The default laser driver only supports laser on and off. Here you control the eĂ­ntensity with
    automatically disabled.
    #define SUPPORT_LASER 1
    #define LASER_PIN HEATER_0_PIN
    #define LASER_ON_HIGH 1
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define DEFAULT_PRINTER_MODE 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 0
    #define ENDSTOP_X_BACK_ON_HOME 10
    #define ENDSTOP_Y_BACK_ON_HOME 10
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 1
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 550
    #define Y_MAX_LENGTH 270
    #define Z_MAX_LENGTH 115
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 2
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 2
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 1
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 40
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 0
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 1
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 1
    #define UI_ANIMATION 0
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 1
    #define MOTOR_DRIVER_1(var) StepperDriver<26,28,24,0,0> var(80,10)
        "editMode": 2,
        "processor": 0,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 80,
        "yStepsPerMM": 80,
        "zStepsPerMM": 80,
        "xInvert": 0,
        "xInvertEnable": 0,
        "eepromMode": 2,
        "yInvert": 0,
        "yInvertEnable": 0,
        "zInvert": "1",
        "zInvertEnable": 0,
        "extruder": [],
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 1,
        "yMinEndstop": 1,
        "zMinEndstop": 0,
        "xMaxEndstop": 0,
        "yMaxEndstop": 0,
        "zMaxEndstop": 0,
        "motherboard": 33,
        "driveSystem": 1,
        "xMaxSpeed": 200,
        "xHomingSpeed": 40,
        "xTravelAcceleration": 1000,
        "xPrintAcceleration": 1000,
        "yMaxSpeed": 200,
        "yHomingSpeed": 40,
        "yTravelAcceleration": 1000,
        "yPrintAcceleration": 1000,
        "zMaxSpeed": 2,
        "zHomingSpeed": 2,
        "zTravelAcceleration": 100,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 550,
        "yLength": 270,
        "zLength": 115,
        "alwaysCheckEndstops": "1",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 10,
        "yEndstopBack": 10,
        "zEndstopBack": 0,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 1,
        "directionDelay": 0,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
            "name": "Extruder 1",
            "step": "ORIG_E1_STEP_PIN",
            "dir": "ORIG_E1_DIR_PIN",
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "0",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "0",
        "hasHeatedBed": "0",
        "enableZProbing": "0",
        "extrudeMaxLength": 160,
        "featureController": 0,
        "uiPrinterName": "RepRap",
        "uiPrinterCompany": "Home made",
        "uiPagesDuration": 4000,
        "uiAnimation": "0",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiPresetBedTempPLA": 60,
        "uiPresetBedABS": 110,
        "uiPresetExtruderPLA": 190,
        "uiPresetExtruderABS": 240,
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 1,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 0,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 275,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbePin": -1,
        "zProbeBedDistance": 10,
        "zProbePullup": "0",
        "zProbeOnHigh": "0",
        "zProbeXOffset": 0,
        "zProbeYOffset": 0,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 2,
        "zProbeXYSpeed": 150,
        "zProbeHeight": 40,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "1",
        "zProbeX1": 20,
        "zProbeY1": 20,
        "zProbeX2": 160,
        "zProbeY2": 20,
        "zProbeX3": 100,
        "zProbeY3": 160,
        "zProbeSwitchingDistance": 1,
        "zProbeRepetitions": 1,
        "sdSupport": "0",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 0,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": "ORIG_PS_ON_PIN",
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "distortionXMin": 10,
        "distortionXMax": 190,
        "distortionYMin": 10,
        "distortionYMax": 190,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "primaryPort": 0,
        "numMotorDrivers": 1,
        "motorDrivers": [
                "t": "Stepper",
                "s": "StepperDriver<26,28,24,0,0> var(80,10)",
                "invertEnable": "0",
                "invertDirection": "0",
                "stepsPerMM": 80,
                "speed": 10,
                "dirPin": 28,
                "stepPin": 26,
                "enablePin": 24
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
        "manualConfig": "",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 0,
        "zProbeZOffset": 0,
        "uiBedCoating": "1",
        "langEN": "1",
        "langDE": "1",
        "langNL": "0",
        "langPT": "1",
        "langIT": "1",
        "langES": "1",
        "langFI": "0",
        "langSE": "0",
        "langFR": "1",
        "langCZ": "0",
        "langPL": "1",
        "langTR": "1",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "supportLaser": "1",
        "laserPin": "HEATER_0_PIN",
        "laserOnHigh": "1",
        "defaultPrinterMode": 1,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 0,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 5,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 0,
        "version": 92.9,
        "primaryPortName": ""
  • Think the problem is that you have not defined a extruder.Even if you don´t use it as Printer it´s still a printer firmware.
    May be i find the time the next days to setup a ramps/mega to test
  • Ok, You were right. I didn't have defined extruder.
    Now I added new extruder, but... What pins should I choose for "temperature sensor pin" and "heater pin"? What's an extruder role in laser mode?
  • You can select fake temperature sensor and heater -1 hopefully works meaning you have none. That makes it a tool without extruder function.
  • Thanks for your response RAyWB and Repetier. I defined extruder and now everything works like it supposed to work in laser mode,
    Thanks for your help!
  • Hello
    I would need a hand if possible.
    I purchased a 5.5W laser
    and I wanted to connect it to the ramps - repetier
    but I'm not a programmer and I don't know what to do.
    where I have to connect the 12V (PIN on the ramps) and the PWM signal on which pin.
    do i also need to program the firmware?
    What should I write...?
    Thank you
  • Lser differ, but if it is similar to mine and has 12V plus a TTL pin then you connect 12V to always on 12V or as I did it define a fan e.g. connected to D10 so you can control if the laser is powered at all. If it gets power you have a small light you can use to position and focus. With fan on (100%)/off you can control it. The 5V TTL pin can be connected to any unused digital output just make sure you write firmware to use that pin. As soon as it goes high laser will run full power so make sure you are not in same room or you are very good protected with special glases and a surrounding to printer. These lasers are very dangerous when enabled. Even with correct laser glases I never look into it - it just hurts the eye.
    And yes you need to modify firmware to us ethe laser correctly in laser mode etc. so it only is enabled on moves, ...
  • I tried to connect 12V on the D10 (extruder output) but starting the list it does not turn on.
    Do I have to manually turn on the extruder from the button?
    I downloaded the plug-in for inkscape but it doesn't create a Gcode for the fan ..?
    What do I control this blessed fan with?
    I would like to have a PWM control, which pin should I use and what should I change in the firmware?
    unfortunately I'm not a programmer I need clear info ..
    Thanks so much
  • You need to assign the pin to fan function then you can control it with M106 and M107 or in any host software with fan control.
    In V1 you have no hardware PWM for laser. You can modify the code to do so as discussed in several threads here in forum.  But for cutting you just need a matching speed. Hope inkscape plugin still works. I think a update of inkscape made it non functional as it created wrong sizes:-(
  • I'm sorry
    but I don't understand what it means to assign the pin to the fan function?
    unfortunately I'm not a programmer and if you please explain to me what to change maybe I can do it.
    what should I change in the configuration.h file?
  • I have read many pages here but none that clearly explain what to do.
    Why don't you just tell me to edit with this text and which pin to use?
    you talk to me about not being able to use PWM and that from v2 it will be possible but when does V2 come out?
  • which host fan control software do you recommend for making grayscale drawings?
  • V2 is out but the AVR support is not finished. Currently only some 32 bit boards are supported.
    What I mean is in configuration.h set 10 as pin number for the fan. Or better use our configuration tool to have a interactive configuration for V1. But creating a firmware is a bit of programming. You configure a software source code compile and upload it, so basic understanding helps especially on errors.
    I never made grayscale drawings so never testen any software for it. It is on my long todo list, but being fdm software provider in first place that is not highest priority.
