BLTouch not working
When I try to go home the bltouch pin drops and bed drives into hot end, I tried triggering it by hand did not stop the z from moving
here is my config.h.. can someone have a look please and thank you..
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
This file is optimized for version 1.0.3
as you expect.
#define NUM_EXTRUDER 2
#define MOTHERBOARD 33
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 1
#define XAXIS_STEPS_PER_MM 159.75
#define YAXIS_STEPS_PER_MM 159.75
#define ZAXIS_STEPS_PER_MM 105.5
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define SHARED_EXTRUDER_HEATER 1
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 150
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_WAIT_RETRACT_TEMP 45
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 150
#define EXT1_TEMPSENSOR_TYPE 1
#define EXT1_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT1_HEATER_PIN -1
#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define EXT1_INVERSE 0
#define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define EXT1_ENABLE_ON 0
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 3
#define EXT1_PREHEAT_TEMP 190
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 45
#define RETRACTION_LONG_LENGTH 45
#define RETRACTION_SPEED 60
#define RETRACTION_Z_LIFT 2
#define RETRACTION_UNDO_EXTRA_LENGTH 47
#define RETRACTION_UNDO_EXTRA_LONG_LENGTH 5
#define RETRACTION_UNDO_SPEED 60
#define FILAMENTCHANGE_SHORTRETRACT 0
#define FILAMENTCHANGE_LONGRETRACT 47
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 0
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 2
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 340
#define Y_MAX_LENGTH 340
#define Z_MAX_LENGTH 320
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 50
#define PARK_POSITION_Z_RAISE 50
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 100
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 50
#define HOMING_ORDER HOME_ORDER_XYTZ
#define ZHOME_PRE_RAISE 0
#define ZHOME_PRE_RAISE_DISTANCE 5
#define RAISE_Z_ON_TOOLCHANGE 5
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 185
#define ZHOME_Y_POS 225
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 2
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 1
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define MAX_FAN_PWM 255
#define FEATURE_WATCHDOG 0
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 5
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 22.8
#define Z_PROBE_SPEED 5
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 4
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 4
#define Z_PROBE_DELAY 0
#define Z_PROBE_START_SCRIPT "M340 P0 S770"
#define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500"
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 340
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 20
#define Z_PROBE_Y3 340
#define BED_LEVELING_METHOD 1
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "3X3D HyperCube"
#define UI_PRINTER_COMPANY "3X3D"
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_HEAD "3X3D... HyperCube 420"
#define NUM_MOTOR_DRIVERS 0
"editMode": 2,
"processor": 0,
"baudrate": 115200,
"bluetoothSerial": -1,
"bluetoothBaudrate": 115200,
"xStepsPerMM": 159.75,
"yStepsPerMM": 159.75,
"zStepsPerMM": 105.5,
"xInvert": 0,
"x2Invert": 0,
"xInvertEnable": 0,
"eepromMode": 1,
"yInvert": 0,
"y2Invert": 0,
"yInvertEnable": 0,
"zInvert": 0,
"z2Invert": 0,
"z3Invert": 0,
"z4Invert": 0,
"zInvertEnable": 0,
"extruder": [
"id": 0,
"heatManager": 3,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 1,
"sensorPin": "TEMP_0_PIN",
"heaterPin": "HEATER_0_PIN",
"maxFeedrate": 50,
"startFeedrate": 20,
"invert": "0",
"invertEnable": "0",
"acceleration": 5000,
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetractTemp": 150,
"waitRetractUnits": 0,
"waitRetract": 0,
"stepsPerMM": 150,
"coolerPin": -1,
"coolerSpeed": 255,
"selectCommands": "",
"deselectCommands": "",
"xOffset": 0,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"name": "Extruder 0",
"step": "ORIG_E0_STEP_PIN",
"dir": "ORIG_E0_DIR_PIN",
"advanceBacklashSteps": 0,
"decoupleTestPeriod": 12,
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"preheat": 190
"id": 1,
"heatManager": 3,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 1,
"heaterPin": -1,
"maxFeedrate": 50,
"invert": "0",
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetract": 0,
"stepsPerMM": 150,
"coolerPin": -1,
"coolerSpeed": 255,
"xOffset": 0,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"name": "Extruder 1",
"step": "ORIG_E1_STEP_PIN",
"dir": "ORIG_E1_DIR_PIN",
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"preheat": 190
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 1,
"yMinEndstop": 1,
"zMinEndstop": 4,
"xMaxEndstop": 0,
"yMaxEndstop": 0,
"zMaxEndstop": 0,
"x2MinEndstop": 0,
"y2MinEndstop": 0,
"x2MaxEndstop": 0,
"y2MaxEndstop": 0,
"motherboard": 33,
"driveSystem": 1,
"xMaxSpeed": 200,
"xHomingSpeed": 40,
"xTravelAcceleration": 1000,
"xPrintAcceleration": 1000,
"yMaxSpeed": 200,
"yHomingSpeed": 40,
"yTravelAcceleration": 1000,
"yPrintAcceleration": 1000,
"zMaxSpeed": 100,
"zHomingSpeed": 50,
"zTravelAcceleration": 100,
"zPrintAcceleration": 100,
"xMotor": {
"name": "X motor",
"step": "ORIG_X_STEP_PIN",
"dir": "ORIG_X_DIR_PIN",
"enable": "ORIG_X_ENABLE_PIN"
"yMotor": {
"name": "Y motor",
"step": "ORIG_Y_STEP_PIN",
"dir": "ORIG_Y_DIR_PIN",
"enable": "ORIG_Y_ENABLE_PIN"
"zMotor": {
"name": "Z motor",
"step": "ORIG_Z_STEP_PIN",
"dir": "ORIG_Z_DIR_PIN",
"enable": "ORIG_Z_ENABLE_PIN"
"enableBacklash": "0",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"stepperInactiveTime": 360,
"maxInactiveTime": 0,
"xMinPos": 0,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 370,
"yLength": 450,
"zLength": 320,
"alwaysCheckEndstops": "0",
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "0",
"xHomeDir": "-1",
"yHomeDir": "-1",
"zHomeDir": "-1",
"xEndstopBack": 1,
"yEndstopBack": 1,
"zEndstopBack": 0,
"deltaDiagonalRod": 445,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"deltaDiagonalCorrA": 0,
"deltaDiagonalCorrB": 0,
"deltaDiagonalCorrC": 0,
"deltaMaxRadius": 150,
"deltaRadiusCorrA": 0,
"deltaRadiusCorrB": 0,
"deltaRadiusCorrC": 0,
"deltaXOffsetSteps": 0,
"deltaYOffsetSteps": 0,
"deltaZOffsetSteps": 0,
"deltaSegmentsPerLine": 20,
"stepperHighDelay": 0,
"directionDelay": 0,
"allowQuadstepping": "1",
"doubleStepDelay": 0,
"maxJerk": 20,
"maxZJerk": 0.3,
"moveCacheSize": 16,
"moveCacheLow": 10,
"lowTicksPerMove": 250000,
"enablePowerOnStartup": "1",
"echoOnExecute": "1",
"sendWaits": "1",
"ackWithLineNumber": "1",
"killMethod": 1,
"useAdvance": "0",
"useQuadraticAdvance": "0",
"powerInverting": 0,
"mirrorX": 0,
"mirrorXMotor": {
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": "0",
"mirrorZMotor": {
"mirrorZ3": "0",
"mirrorZ3Motor": {
"name": "Extruder 2",
"step": "ORIG_E2_STEP_PIN",
"dir": "ORIG_E2_DIR_PIN",
"mirrorZ4": "0",
"mirrorZ4Motor": {
"name": "Extruder 3",
"step": "ORIG_E3_STEP_PIN",
"dir": "ORIG_E3_DIR_PIN",
"dittoPrinting": "0",
"featureServos": "1",
"servo0Pin": 11,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"featureWatchdog": "0",
"hasHeatedBed": "0",
"enableZProbing": "1",
"extrudeMaxLength": 160,
"homeOrder": "HOME_ORDER_XYTZ",
"featureController": 11,
"uiPrinterName": "3X3D HyperCube",
"uiPrinterCompany": "3X3D",
"uiPagesDuration": 4000,
"uiHeadline": "3X3D... Only those with a big gun are worthy to rule the world...",
"uiDisablePageswitch": "1",
"uiAutoReturnAfter": 30000,
"featureKeys": "0",
"uiEncoderSpeed": 1,
"uiReverseEncoder": "0",
"uiKeyBouncetime": 10,
"uiKeyFirstRepeat": 500,
"uiKeyReduceRepeat": 50,
"uiKeyMinRepeat": 50,
"featureBeeper": "0",
"uiMinHeatedBed": 30,
"uiMaxHeatedBed": 120,
"uiMinEtxruderTemp": 170,
"uiMaxExtruderTemp": 260,
"uiExtruderFeedrate": 2,
"maxBedTemperature": 120,
"bedSensorType": 1,
"bedSensorPin": "TEMP_1_PIN",
"bedHeatManager": 0,
"bedPreheat": 55,
"bedUpdateInterval": 5000,
"bedPidDriveMin": 80,
"bedPidDriveMax": 255,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"bedDecoupleTestPeriod": 300,
"caseLightPin": -1,
"caseLightDefaultOn": "1",
"bedSkipIfWithin": 3,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"tempHysteresis": 0,
"pidControlRange": 20,
"skipM109Within": 2,
"extruderFanCoolTemp": 50,
"minTemp": 150,
"maxTemp": 275,
"minDefectTemp": -10,
"maxDefectTemp": 290,
"arcSupport": "1",
"forceChecksum": "0",
"sdExtendedDir": "1",
"featureFanControl": "1",
"fanPin": "ORIG_FAN_PIN",
"featureFan2Control": "0",
"fan2Pin": "ORIG_FAN2_PIN",
"fanThermoPin": -1,
"fanThermoMinPWM": 128,
"fanThermoMaxPWM": 255,
"fanThermoMinTemp": 45,
"fanThermoMaxTemp": 60,
"fanThermoThermistorPin": -1,
"fanThermoThermistorType": 1,
"scalePidToMax": 0,
"zProbePin": "ORIG_Z_MIN_PIN",
"zProbeBedDistance": 10,
"zProbeDisableHeaters": "0",
"zProbePullup": "0",
"zProbeOnHigh": "1",
"zProbeXOffset": 0,
"zProbeYOffset": 0,
"zProbeWaitBeforeTest": "0",
"zProbeSpeed": 2,
"zProbeXYSpeed": 150,
"zProbeHeight": 0,
"zProbeStartScript": "M340 P0 S770",
"zProbeFinishedScript": "M340 P0 S1500",
"featureAutolevel": "1",
"zProbeX1": 20,
"zProbeY1": 20,
"zProbeX2": 340,
"zProbeY2": 20,
"zProbeX3": 20,
"zProbeY3": 340,
"zProbeSwitchingDistance": 4,
"zProbeRepetitions": 2,
"zProbeMedian": "0",
"zProbeEveryPoint": "",
"sdSupport": "0",
"sdCardDetectPin": -1,
"sdCardDetectInverted": "0",
"uiStartScreenDelay": 1000,
"xEndstopBackMove": 5,
"yEndstopBackMove": 5,
"zEndstopBackMove": 2,
"xEndstopRetestFactor": 3,
"yEndstopRetestFactor": 3,
"zEndstopRetestFactor": 3,
"xMinPin": "ORIG_X_MIN_PIN",
"yMinPin": "ORIG_Y_MIN_PIN",
"zMinPin": "ORIG_Z_MIN_PIN",
"xMaxPin": "ORIG_X_MAX_PIN",
"yMaxPin": "ORIG_Y_MAX_PIN",
"zMaxPin": "ORIG_Z_MAX_PIN",
"x2MinPin": -1,
"y2MinPin": -1,
"x2MaxPin": -1,
"y2MaxPin": -1,
"deltaHomeOnPower": "0",
"fanBoardPin": -1,
"heaterPWMSpeed": 0,
"featureBabystepping": "1",
"babystepMultiplicator": 1,
"pdmForHeater": "0",
"pdmForCooler": "0",
"psOn": "ORIG_PS_ON_PIN",
"mixingExtruder": "0",
"featureAxisComp": "0",
"axisCompTanXY": 0,
"axisCompTanXZ": 0,
"axisCompTanYZ": 0,
"retractOnPause": 2,
"pauseStartCommands": "",
"pauseEndCommands": "",
"distortionCorrection": "0",
"distortionCorrectionR": 100,
"distortionPermanent": "1",
"distortionEndDegrade": 1,
"distortionXMin": 10,
"distortionXMax": 190,
"distortionYMin": 10,
"distortionYMax": 190,
"sdRunOnStop": "",
"featureRetraction": "1",
"autoretractEnabled": "0",
"retractionLength": 150,
"retractionLongLength": 150,
"retractionSpeed": 60,
"retractionZLift": 2,
"retractionUndoExtraLength": 155,
"retractionUndoExtraLongLength": 5,
"retractionUndoSpeed": 60,
"filamentChangeXPos": 0,
"filamentChangeYPos": 0,
"filamentChangeZAdd": 2,
"filamentChangeRehome": 1,
"filamentChangeShortRetract": 0,
"filamentChangeLongRetract": 150,
"fanKickstart": 200,
"servo0StartPos": -1,
"servo1StartPos": -1,
"servo2StartPos": -1,
"servo3StartPos": -1,
"uiDynamicEncoderSpeed": "1",
"uiServoControl": 0,
"killIfSensorDefect": "0",
"jamSteps": 220,
"jamSlowdownSteps": 320,
"jamSlowdownTo": 70,
"jamErrorSteps": 500,
"jamMinSteps": 10,
"jamAction": 1,
"jamMethod": 1,
"primaryPort": 0,
"numMotorDrivers": 0,
"motorDrivers": [
"t": "None",
"s": "",
"invertDirection": "0",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"invertEndstop": "0",
"minEndstop": "1",
"endstopPullup": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"manualConfig": "",
"zHomeMinTemperature": 0,
"zHomeXPos": 185,
"zHomeYPos": 225,
"zHomeHeatHeight": 20,
"zHomeHeatAll": "1",
"zProbeZOffsetMode": 0,
"zProbeZOffset": 0,
"zProbeDelay": 0,
"uiBedCoating": "1",
"langEN": "1",
"langDE": "0",
"langNL": "0",
"langPT": "0",
"langIT": "0",
"langES": "0",
"langFI": "0",
"langSE": "0",
"langFR": "0",
"langCZ": "0",
"langPL": "0",
"langTR": "0",
"accelerationFactorTop": 100,
"bendingCorrectionA": 0,
"bendingCorrectionB": 0,
"bendingCorrectionC": 0,
"supportLaser": "0",
"laserPin": -1,
"laserOnHigh": "1",
"laserWarmupTime": 0,
"defaultPrinterMode": 0,
"laserPwmMax": 255,
"laserWatt": 2,
"supportCNC": "0",
"cncWaitOnEnable": 300,
"cncWaitOnDisable": 0,
"cncEnablePin": -1,
"cncEnableWith": "1",
"cncDirectionPin": -1,
"cncDirectionCW": "1",
"cncPwmMax": 255,
"cncRpmMax": 8000,
"cncSafeZ": 150,
"startupGCode": "",
"jsonOutput": "0",
"bedLevelingMethod": 1,
"bedCorrectionMethod": 0,
"bedLevelingGridSize": 5,
"bedLevelingRepetitions": 5,
"bedMotor1X": 0,
"bedMotor1Y": 0,
"bedMotor2X": 200,
"bedMotor2Y": 0,
"bedMotor3X": 100,
"bedMotor3Y": 200,
"zProbeRequiresHeating": "0",
"zProbeMinTemperature": 150,
"adcKeypadPin": -1,
"sharedExtruderHeater": "1",
"extruderSwitchXYSpeed": 100,
"dualXAxis": "0",
"boardFanSpeed": 255,
"keepAliveInterval": 2000,
"moveXWhenHomed": "0",
"moveYWhenHomed": "0",
"moveZWhenHomed": "0",
"preheatTime": 30000,
"multiZEndstopHoming": "0",
"z2MinMaxPin": -1,
"z2MinMaxEndstop": 0,
"extruderIsZProbe": "0",
"boardFanMinSpeed": 0,
"doorPin": -1,
"doorEndstop": 1,
"zhomePreRaise": 0,
"zhomePreRaiseDistance": 5,
"dualXResolution": "0",
"x2axisStepsPerMM": 100,
"coolerPWMSpeed": 0,
"maxFanPWM": 255,
"raiseZOnToolchange": 5,
"distortionLimitTo": 2,
"automaticPowerup": 0,
"hasTMC2130": "0",
"TMC2130Sensorless": "0",
"TMC2130Steathchop": "1",
"TMC2130Interpolate256": "1",
"TMC2130StallguardSensitivity": 0,
"TMC2130PWMAmpl": 255,
"TMC2130PWMGrad": 1,
"TMC2130PWMAutoscale": "1",
"TMC2130PWMFreq": 2,
"TMC2130CSX": -1,
"TMC2130CSY": -1,
&n
is no so good. When you release the probe it must be off. So you should pre raise Z so this is ensured.
Check M119 if signal is good.
Must also be enough to untigger z probe. Also motion speeds must be fast enough so it untriggers in time.
As far as I know the main problem with BLtouch is that you need to retract z fast enough or it goes in error state. So that is the main point you must ensure.
So look closely what is happening when exactly to see at which point the sensor fails and fix it by increasing distances or speeds in that phase.
