Z probe height
Im using ramps 1.4 with repetier firmware and host program. No matter what value I change the z probe height to it dosnt help keep from my extuder being to close to the bed to print, cause jamming in my extruder. I have changed values both in the eeprom and the configure.h file with seemly little to no results. I have made the values both positive and negative to see if it would get closer or further from the bed. From what I can tell all of my auto bed level is really innaccurate and when it does work it seems its just by luck. 1 out of ever 5+ bed levels might get me one printable z axis distance that wont jam extruder. Most of the time the extruder is just mashed in to the bed. Is there another setting that im missing? is auto bed level just that terrible? I don't understand.
from what I can tell the z probeis working. I can manually deploy it with gcode commands, and undeploy it. it does click in when iut touches print bed. If I try to auto level 2x in a row with out powering off printer first it will cause the printer to act werid, all the axis will go seperate ways and the z probe led light will flash, not really sure whats the deal with that either.
  • Below is a current copy of my config.h files Z probe settings.
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_HEIGHT 1
    #define Z_PROBE_START_SCRIPT "M340 P0 S700"
    #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500"
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 120
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 120
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 0
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 1
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 1
    #define UI_ANIMATION 0
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
  • so nobody understands this firmware? I think maybe this firmware is not good with z probe?
  • people say to change Z probe height to change distance from nozzle to bed but I have found this setting to be useless since it dosnt acutally do any thing.
  • i see videos of when other people home their Z axis their probe deploys to i assume be used sort of like a z min endstop, my probe doesnt do this on Z home.
  • I am having a problem with my bed leveling that I hope fits this thread. In the past week, when my Da Vinci 2.0a tries to auto bed level, the left-hand extruder hits the side of the bed sensor as it is moving across thus causing a G29 bed level error and disables printing. It has never done this until now and nothing has changed (ie firmware, software, etc). Thoughts? It's running Repetier 0.92.10M firmware and I'm using Repetier-Host 2.1.3. I've tried disabling auto level with M321 S1 but it stills tries to auto level every time it tries to print. I'm sending the code through Repetier-Host.
