X and Y Hit end Stop Normally But....
Hey again, still calibrating my machine. Each axis when homing, hits the end stop correctly, but then retracts about 10 percent of my printable area, then goes back to the end stop. A back and forth motion each time I home. I cannot find a solution to turn this off or change a value in the EEPROM or in Host. How may i go about fixing this? Thank you in advance.
~Drew
~Drew
~Drew
~Drew
Any other ideas?
~Drew
A new issue has arisen. My prints are unreasonably slow now. It will home at a good speed, go over to the print bed at a good speed, then just drop in speed and go extremely slow when actually printing or using manual control. I have Cura as my slicer and I have set my settings but no matter how I set them in Speed and Quality, it still runs extremely slow. When I change these settings up higher, it goes over to the print bed fast like it should, then slows back down, even though all the numbers are high. What may be causing this?
Very, very much appreciated.
~Drew
https://www.prusaprinters.org/calculator/
normal values
1.8 deg(200 step) 1/16 micro stepping, GT2 2mm belt pitch, 20 tooth pully = 80 steps/mm
G1 X0
G1 X200 F6000
That moves 100mm/s so should take 2 seconds + acceleration time. You can test with other speeds as well. If it works you know speeds are converted correctly. Make sure in host/server speed multiplier is at 100%!
Remember to save settings and reslice using a slicer. YOu should then see the F... parameter get increasing speeds.
~Drew
#define MAX_FEEDRATE_Y
#define MAX_FEEDRATE_Z
~Drew
~Drew
~Drew
~Drew
