Runnout filament sensor with Repetier
Hi!
I'm using a RAMPS 1.4 with an optical sensor as a filament runout sensor.
I have tried two pins as the signal:
-Servo pint (D4)
-Z Max pin
When I activate the "DEBUG_JAM", the command M512 can correctly see if there is a filament (1) or no filament(0)
I use the following configuration:
#define JAM_METHOD 3
#define JAM_ACTION 1
Also tried Jam_ACTION 2 and JAM_METHOD 2, without success.
Tried running the print from SD, from Repetier Host and Repetier Server without success.
I tried Repetier V0.93.9 and V1.0.3 without success.
I feel like the function TEST_EXTRUDER_JAM(x) is not triggered correctly, unless there is something I'm missing.
I try to remove the filament from the sensor and put it back many times during a print and it never stops.
-Servo pint (D4)
-Z Max pin
