Wrong X Y in G1 movement
I modified my 3d printer to use also an laser for engraving.
To control it I have an raspberry pi with software octopi on it.
When I engrave something the printer prints fine but sometimes it seems that it gets wrong coordinates. So for example it gets a line completely through the think I want to engrave, even outside of the space I want to engrave and then it gets back to the next real point to engrave. For me it looks like it is getting a wrong X or Y Value. Sometimes it even looks like it forgets a point. So it directly engraves to the next point, then for example an edge is missing.
The wrong points are definetly not In the gcode file. I checked it with a gcode viewer. And if printing it twice the faults are not at the same place.
Any idea what this can be?
I am using the actual OctoPi version and the actual repetier firmware, not the development...
Normally the checksum prevents this but if you send
N8833 G1 X100 Y120 *67
and firmware gets
N8833 G1 X10
0 Y120 *67
It will execute G1 X100 as a separate move and triggers an error for next line which it will ignore for missing line number I guess. Just an example of how com errors might cause unexpected moves. But better first compare in log as described.
