BlTouch Delay Issue
Hey Folks
I hope this problem is not solved already, I didn't find a solution in the forum.
As the title says is the problem, that the Probe finished script is executed befor the bed is far enough!
For this reason the bltouch touches the bed again, which will cause sometimes errors.
I found a video on youtube with the similar problem.
https://www.youtube.com/watch?v=K0nOLraXF0Y
You can cleary see/hear that the bed is touched again.
Is there a possibility to set a delay or fix this problem?
Despite that, the BlTouch is working fine.
kind regards
  • can you post your config.h pls
  • edited November 9
    sure
    I have a cartesian printer but i am moving the bed in z and the head in x/y
    Edit:
    I thought i can attach the config.h file here
    So i will ve to post ist
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.3
       as you expect.
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 402
    #define RFSERIAL Serial
    #include "pins.h"
    #undef FAN_PIN
    #define FAN_PIN ORIG_FAN2_PIN
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    #define FAN_THERMO_THERMISTOR_TYPE 0
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 200
    #define YAXIS_STEPS_PER_MM 200
    #define ZAXIS_STEPS_PER_MM 400
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 143.5
    #define EXT0_TEMPSENSOR_TYPE 14
    #define EXT0_STEP_PIN ORIG_E2_STEP_PIN
    #define EXT0_DIR_PIN ORIG_E2_DIR_PIN
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN_PIN
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 370
    #define EXT1_TEMPSENSOR_TYPE 14
    #define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
    #define EXT1_HEATER_PIN HEATER_2_PIN
    #define EXT1_STEP_PIN ORIG_E2_STEP_PIN
    #define EXT1_DIR_PIN ORIG_E2_DIR_PIN
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_HEAT_MANAGER 0
    #define EXT1_PREHEAT_TEMP 0
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_DECOUPLE_TEST_PERIOD 20000
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 14
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 180
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 5
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 1
    #define INVERT_Z2_DIR 1
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 287
    #define Y_MAX_LENGTH 279
    #define Z_MAX_LENGTH 375
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 0
    #define DISTORTION_YMIN 30
    #define DISTORTION_XMAX 254
    #define DISTORTION_YMAX 245
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 4
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 4
    #define HOMING_ORDER HOME_ORDER_XYTZ
    #define ZHOME_PRE_RAISE 2
    #define ZHOME_PRE_RAISE_DISTANCE 5
    #define ZHOME_HEAT_ALL 0
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 150
    #define ZHOME_Y_POS 150
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 2
    #define DIRECTION_DELAY 0
    #define STEP_DOUBLER_FREQUENCY 80000
    #define ALLOW_QUADSTEPPING 1
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E2_STEP_PIN
    #define X2_DIR_PIN    ORIG_E2_DIR_PIN
    #define X2_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define FEATURE_TWO_YSTEPPER 1
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define FEATURE_TWO_ZSTEPPER 1
    #define Z2_STEP_PIN   ORIG_E0_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E0_DIR_PIN
    #define Z2_ENABLE_PIN ORIG_E0_ENABLE_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 1
    #define SERVO0_PIN 5
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS  1500
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_BED_DISTANCE 5
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 20
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_SWITCHING_DISTANCE 5
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 1.86
    #define Z_PROBE_DELAY 0
    #define Z_PROBE_START_SCRIPT "M340 P0 S700"
    #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500"
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 0
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 286
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 0
    #define Z_PROBE_Y3 268
    #define BED_LEVELING_METHOD 1
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 7
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_COMPANY "Jonas"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
        "editMode": 2,
        "processor": 1,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 200,
        "yStepsPerMM": 200,
        "zStepsPerMM": 400,
        "xInvert": 0,
        "x2Invert": 0,
        "xInvertEnable": 0,
        "eepromMode": 1,
        "yInvert": 0,
        "y2Invert": 0,
        "yInvertEnable": 0,
        "zInvert": "1",
        "z2Invert": "1",
        "z3Invert": 0,
        "z4Invert": 0,
        "zInvertEnable": "0",
        "extruder": [
                "id": 0,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 14,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 50,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "0",
                "acceleration": 5000,
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 143.5,
                "coolerPin": "ORIG_FAN_PIN",
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 2",
                    "step": "ORIG_E2_STEP_PIN",
                    "dir": "ORIG_E2_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "preheat": 190
                "id": 1,
                "heatManager": 0,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 14,
                "sensorPin": "TEMP_2_PIN",
                "heaterPin": "HEATER_2_PIN",
                "maxFeedrate": 50,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetract": 0,
                "stepsPerMM": 370,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                "decoupleTestPeriod": 20,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                    "name": "Extruder 1",
                    "step": "ORIG_E1_STEP_PIN",
                    "dir": "ORIG_E1_DIR_PIN",
                "preheat": 0
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 2,
        "yMinEndstop": 2,
        "zMinEndstop": 4,
        "xMaxEndstop": 2,
        "yMaxEndstop": 2,
        "zMaxEndstop": 2,
        "x2MinEndstop": 0,
        "y2MinEndstop": 0,
        "x2MaxEndstop": 0,
        "y2MaxEndstop": 0,
        "motherboard": 402,
        "driveSystem": 0,
        "xMaxSpeed": 200,
        "xHomingSpeed": 40,
        "xTravelAcceleration": 1000,
        "xPrintAcceleration": 1000,
        "yMaxSpeed": 200,
        "yHomingSpeed": 40,
        "yTravelAcceleration": 1000,
        "yPrintAcceleration": 1000,
        "zMaxSpeed": 4,
        "zHomingSpeed": 4,
        "zTravelAcceleration": 100,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 287,
        "yLength": 279,
        "zLength": 375,
        "alwaysCheckEndstops": "1",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 1,
        "yEndstopBack": 1,
        "zEndstopBack": 0,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 2,
        "directionDelay": 0,
        "stepDoublerFrequency": 80000,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": "0",
        "mirrorXMotor": {
        "mirrorY": "1",
        "mirrorYMotor": {
        "mirrorZ": "1",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "1",
        "servo0Pin": 5,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "0",
        "hasHeatedBed": "1",
        "enableZProbing": "1",
        "extrudeMaxLength": 160,
        "homeOrder": "HOME_ORDER_XYTZ",
        "featureController": 7,
        "uiPrinterName": "RepRap",
        "uiPrinterCompany": "Jonas",
        "uiPagesDuration": 4000,
        "uiHeadline": "",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 14,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 0,
        "bedPreheat": 55,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 180,
        "maxTemp": 275,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN2_PIN",
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 0,
        "scalePidToMax": 0,
        "zProbePin": "ORIG_Z_MIN_PIN",
        "zProbeBedDistance": 5,
        "zProbeDisableHeaters": "0",
        "zProbePullup": "1",
        "zProbeOnHigh": "1",
        "zProbeXOffset": 0,
        "zProbeYOffset": 20,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 2,
        "zProbeXYSpeed": 150,
        "zProbeHeight": 1.86,
        "zProbeStartScript": "M340 P0 S700",
        "zProbeFinishedScript": "M340 P0 S1500",
        "featureAutolevel": "1",
        "zProbeX1": 0,
        "zProbeY1": 20,
        "zProbeX2": 286,
        "zProbeY2": 20,
        "zProbeX3": 0,
        "zProbeY3": 268,
        "zProbeSwitchingDistance": 5,
        "zProbeRepetitions": 1,
        "zProbeMedian": "0",
        "zProbeEveryPoint": "",
        "sdSupport": "0",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 5,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": "ORIG_PS_ON_PIN",
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "distortionXMin": 0,
        "distortionXMax": 254,
        "distortionYMin": 30,
        "distortionYMax": 245,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": "1500",
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 1,
        "primaryPort": 1,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        "manualConfig": "",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 150,
        "zHomeYPos": 150,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "0",
        "zProbeZOffsetMode": 0,
        "zProbeZOffset": 0,
        "zProbeDelay": 0,
        "uiBedCoating": "1",
        "langEN": "1",
        "langDE": "0",
        "langNL": "0",
        "langPT": "0",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "preventZDisableOnStepperTimeout": "1",
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "laserWarmupTime": 0,
        "defaultPrinterMode": 0,
        "laserPwmMax": 255,
        "laserWatt": 2,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "cncPwmMax": 255,
        "cncRpmMax": 8000,
        "cncSafeZ": 150,
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 1,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 5,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "keepAliveInterval": 2000,
        "moveXWhenHomed": "0",
        "moveYWhenHomed": "0",
        "moveZWhenHomed": "0",
        "preheatTime": 30000,
        "multiZEndstopHoming": "0",
        "z2MinMaxPin": -1,
        "z2MinMaxEndstop": 0,
        "extruderIsZProbe": "0",
        "boardFanMinSpeed": 0,
        "doorPin": -1,
        "doorEndstop": 1,
        "zhomePreRaise": 2,
        "zhomePreRaiseDistance": 5,
        "dualXResolution": "0",
        "x2axisStepsPerMM": 100,
        "coolerPWMSpeed": 0,
        "maxFanPWM": 255,
        "raiseZOnToolchange": 0,
        "distortionLimitTo": 2,
        "automaticPowerup": 0,
        "hasTMC2130": "0",
        "TMC2130Sensorless": "0",
        "TMC2130Steathchop": "1",
        "TMC2130Interpolate256": "1",
        "TMC2130StallguardSensitivity": 0,
        "TMC2130PWMAmpl": 255,
        "TMC2130PWMGrad": 1,
        "TMC2130PWMAutoscale": "1",
        "TMC2130PWMFreq": 2,
        "TMC2130CSX": -1,
  • It is not the finish script. You are mid G32 if I guess it right and finish script is only run when you are completed with all points.
    What I see is that bl touch indicates high with led but firmware doe snot get high signal continuing to move down until bl touch goes into error mode setting it high which firmware sees and goes up. From there on it always goes only up as it is triggered at start. But that is also strange since un runZProbe
        Endstops::update();
        Endstops::update(); // need to call twice for full update!
        if(Endstops::zProbe()) {
            Com::printErrorFLN(PSTR("z-probe triggered before starting probing."));
            return ILLEGAL_Z_PROBE;
    would just stop probing if endstop is high.
    You should run this with host connected and check error messages.
    You may also want to try running it after
    M111 S64
    which will write endstop changes to console/log. Hope it doe snot crash firmware as it can happen if too many changes happen. But if not it might show what signals the bltouch is sending at which time. But you have to watch it yourself - later we can not make sense of it without knowing what exactly happened on printer side on which message.
  • Thanks for your hints and sry for my absence
    I tried to follow your hints but i discoverd a new problem.
    After executing "M111 S64" i can't home z anymore.
    I have no clue why this happens.
    So i made 2 Videos for you guys, before and after executing "M111 S64"
    After calling "M111 S64" BL-Touch keeps blinking and i have to reset the printer to proceed.
    The console says following commands.
    Your first code isn't not calling anything, but perhaps its just my fault and I inserted it wrong.
    Here are the videos.
    https://www.dropbox.com/sh/k36tjmq5n6o7grd/AAAU_ZtoEEU8yXIJVqPCVBAUa?dl=0
  • You say
    while z min endstop has it false so it is unclear if pullup is on or off. Both need to be identical otherwise last one setting it wins.
    M111 S64 can cause a firmware crash if output takes too long which seems to happen. But it has no influence if it would work. I think it is just switching too fast so the crash happens. Output during an interrupt is not allowed for this reason.
    Not sure if pullup changes anything.
  • short reply:
    I changed it, but the problem won't disapear
  • edited November 20
    add:
    i was reading through Antlabs-Documentation
    There are a few points in the Marlin-Documentation which bothers me:
    In Marlin there are following points:
    #define BLTOUCH_DELAY 100
    #define Z_CLEARANCE_DEPLOY_PROBE 15
    #define Z_CLEARANCE_BETWEEN_PROBES 10
    and
    Insert the following G-code into Slic3r or Cura:
    G4 P100 ; delay for BLTouch
    i don't really get, what the BL_TOUCH_DELAY is for
    edit:
    took my information from this site:
    https://www.antclabs.com/bltouch
    edit#2:
    The random errors during autobedleveling where effected cause a broken cable.
    But the sensor is still "pushed down" too early resulting in hitting the board
  • So I guess problem is now solved.
    Delay is to reemploy the probe I guess. Delay or moving up a bit more is the same. Just needs enough space to reemploy so it must move up 10mm so it does not hit bed on doing so. That is what makes the BLTouch so hard - timings and positions must match to work. But if they do it is good.
  • Not really solved, but i don't get anymore errors during homing and autobedleveling
    but the pin is still released too fast, so i hits the bed while it's moving away
    you can here this effect in the video!
    i don't think this is how it should work and believe that it depends on the software.
    perhaps you can integrate a timing-function in the Firmware, where i can define when the "servo" is pushed back.
  • #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500"
    that might take some time but you have do delay. Add a G4 P500 to wait a half second after issuing the command. Don't know the sensor but you might also want to add a R300 to M340  to disable servo signal after a while.
    Might not be the right spot but that is called when it is finished and then positioning continues so without knowing the time I guess this is the point where you need the pause.
  • It see what your intention is.
    How can i implement two commands?
    i guess it should be at:
    #define Z_PROBE_FINISHED_SCRIPT "G4 P500 M340 P0 S1500"
    but i don't get it, how to write two Commands in one line?
    any ideas?
    Then i can try on my own to find the right timing spot
  • #define Z_PROBE_FINISHED_SCRIPT "G4 P500\n M340 P0 S1500"
  • Actually the pause must be after disabling probe
    #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500\nG4 P500"
    should do.
