Printer rebooting every time i try to print lithophane (from SD card)
I'm having an issue with printing lithophanes from my Tevo Tornado. Every time i select the file to print from the SD card it goes back to the home screen (partially covered by SD card files) and then begins to reboot.
I've tried slic3r and cura with different settings and still no luck. Only time it works is when i have my computer directly connected to the printer, but this causes the printer to randomly stop for a few seconds as my computer lags behind.
So far i've looked for answers and have had no luck finding anyone with the same problem. Please let me know if you have any idea what might be causing this and how I can fix it. Thanks.
Here is a video of the problem.
When you run from usb the usb also powers the printer board. Maybe that is the difference helping the board not to brown out. So try form sd card with usb connected as well as test.
You can also reduce print to the beginning to see which part causes the reboot. If it is short enough it will not reboot and a bit more it will reboot. then you know the trouble gcode is in the new lines.
