Prusa i3 MK3
Can anyone help with a printer profile or screenshots of settings for prusa i3 mk3? I am trying to get the server setup so that I can evaluate vs octoprint. I love the interface of repetier vs octoprint. I would like to ensure that I get the setting correct so I do not have to waste materials. Thank you in advance!
So far I am thinking that I am going to make the purchase of this software ~ It's pretty nice!
  • It's not much you can do wrong. Just make sure to have selected "Port is visible even if firmware is not running" if you connect using usb port. Will also work without this but it will always switch between trying and disconnected then because the port is visible.
    If you want to use a pi zero W read this
    https://www.repetier-server.com/knowledgebase/prepare-for-prusa-mk3-on-raspberry-pi-zerow-rambo-einsy-board/
    on how to set it up with our image. Be a bit patient when you connect first time to your wlan. Seems like it needs a bit sometimes to accept it. Once it has connected though is seems to be stable at least for me.
  • So if I understand correctly you dont have to set bed size or any other options to print? There are tons of options that arent configured. Thank you so much for responding!
  • For printing they are not relevant as we only send the gcode. But of course it would be good to set them to meaningful values. Bed size is known and you should also allow y min -3 as default slic3r configs print a dirt line there. But many values like move speeds in manual control and your favourite temperatures or actions on pause/continue are also personal preferences or depend on the filament you use.
    I'm also still improving my settings to my wishes as well. If you send me a pm with email I can send you my xml configuration also it is not perfect at the moment.
    PM'ed let me know if you do not recieve
