no printing from SD card @ Anet A6 Printer
I started to use repetier-host to remote control my Anet A6 3D printer by USB cable.
The connection is OK and works. I can see the temerature curves of the priner and I can control the functions remotely.
NOT works, to start a print from a SD card, witch is in the printer. repetier shows the card and the content but I cant do anything with. No deleting files, no real print starting.
Repetier shows, thats the prist has startet (the printerdisplay not) and stays at 0 percent.
Has someone an idea, how to fix the situation?
  • First make sure the names contain only ascii chars. Anything else can cause problems. Then check the log what command did host send, what did firmware respond.
