Compile errors after using the configuration tool
I tried the configuration tool to install a BLTouch to my printer. Now I get compile errors that were on files not modified. What would cause this?
  • These are the error messages I get:
    Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
    sketch\ui.cpp: In member function 'int UIDisplay::executeAction(unsigned int, bool)':
    ui.cpp:3097: error: 'UI_SET_PRESET_EXTRUDER_TEMP_PLA' was not declared in this scope
                 Extruder::setTemperatureForExtruder(UI_SET_PRESET_EXTRUDER_TEMP_PLA,0);
    ui.cpp:3105: error: 'UI_SET_PRESET_HEATED_BED_TEMP_PLA' was not declared in this scope
                 Extruder::setHeatedBedTemperature(UI_SET_PRESET_HEATED_BED_TEMP_PLA);
    ui.cpp:3110: error: 'UI_SET_PRESET_EXTRUDER_TEMP_ABS' was not declared in this scope
                 Extruder::setTemperatureForExtruder(UI_SET_PRESET_EXTRUDER_TEMP_ABS,0);
    ui.cpp:3118: error: 'UI_SET_PRESET_HEATED_BED_TEMP_ABS' was not declared in this scope
                 Extruder::setHeatedBedTemperature(UI_SET_PRESET_HEATED_BED_TEMP_ABS);
    exit status 1
    This report would have more information with
    "Show verbose output during compilation"
    option enabled in File -> Preferences.
    I have a copy of the original, unmodified firmware that does not have this issue.
