Error reading STL file
I recently designed and printed some Fluke meter accessories on my home 3D printer setup, using STL files exported by SolveSpace. They worked fine, but when I brought the files to work it's giving the error "System.IO.EndOfStreamException: End of stream reached with 80 bytes left to read at RepetierHostExtender.geom.TopoModel.ReadArray(Stream stream, Byte[]data) at RepetierHostExtender.geom.TopoModel.importSTL(String filename, Double scale)". I just downloaded and installed Host V2.1.3 on my system at work, and I get the same error as they do on the computer running the 3D printer. Can you offer any suggestions? The STL files are available at: https://www.thingiverse.com/thing:3108018. ; Thanks!
