Error: Repetier-Host after click on Load for Gcode witn double dot ( : ) sign in name on Server tab
in Bug Reports
Repetier-Host V2.1.3 display Error dialog after click on Load for Gcode witn double dot ( : ) sign in name on Server tab (screenshot.png). Doing on the Windows 10 64bit.
How to reproduce:
1. Genereta and Save to Server Gcode with sign double dot ( : ) in the name (E.g.: rail_mount_up_complete_0.1mm:ABS-ND ).
2. Go to the Server Tab
3. Select this Gcode with double dot ( : ) in name and click on the Load button -> Display Error dialog.
Stack Trace:
Informace o vyvolání ladění JIT najdete na konci této zprávy,
nikoli v tomto dialogovém okně.
************** Text výjimky **************
System.NotSupportedException: Uvedený formát cesty není podporován.
v System.Security.Permissions.FileIOPermission.EmulateFileIOPermissionChecks(String fullPath)
v System.Security.Permissions.FileIOPermission.QuickDemand(FileIOPermissionAccess access, String fullPath, Boolean checkForDuplicates, Boolean needFullPath)
v System.IO.FileInfo.Init(String fileName, Boolean checkHost)
v RepetierHost.view.RepetierEditor.set_PreferredSaveName(String value)
v RepetierServerConnector.ServerPrint.buttonPreview_Click(Object sender, EventArgs e)
v System.Windows.Forms.Control.OnClick(EventArgs e)
v System.Windows.Forms.Button.OnClick(EventArgs e)
v System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
v System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
v System.Windows.Forms.Control.WndProc(Message& m)
v System.Windows.Forms.ButtonBase.WndProc(Message& m)
v System.Windows.Forms.Button.WndProc(Message& m)
v System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Načtená sestavení **************
mscorlib
Verze sestavení: 4.0.0.0
Verze Win32: 4.7.3132.0 built by: NET472REL1LAST
Základ kódu (CodeBase): file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
RepetierHost
Verze sestavení: 2.1.3.0
Verze Win32: 2.1.3.0
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/RepetierHost.exe
Verze Win32: 4.7.3056.0 built by: NET472REL1
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Verze Win32: 4.7.3151.0 built by: NET472REL1LAST_B
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
RepetierHostExtender
Verze sestavení: 1.0.0.0
Verze Win32: 1.0.0.0
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/RepetierHostExtender.DLL
System.Configuration
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Verze Win32: 4.7.3160.0 built by: NET472REL1LAST_C
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
OpenTK
Verze sestavení: 2.0.0.0
Verze Win32: 2.0.0
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/OpenTK.DLL
System.Windows.Forms.resources
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_cs_b77a5c561934e089/System.Windows.Forms.resources.dll
Accessibility
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
ColorSlider
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/ColorSlider.DLL
CuraEngine
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/plugins/CuraEngine/CuraEngine.dll
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/plugins/RepetierServerConnector/RepetierServerConnector.dll
RRFirmwares
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/plugins/RRFirmwares/RRFirmwares.dll
SlicerSlic3r
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/plugins/SlicerSlic3r/SlicerSlic3r.dll
SlicerSlic3rPE
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/plugins/SlicerSlic3rPE/SlicerSlic3rPE.dll
System.ServiceProcess
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
Newtonsoft.Json
Verze sestavení: 6.0.0.0
Verze Win32: 6.0.8.18111
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/Newtonsoft.Json.DLL
websocket-sharp
Verze sestavení: 1.0.2.59611
Verze Win32: 1.0.2.59611
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/plugins/RepetierServerConnector/websocket-sharp.DLL
OpenTK.GLControl
Verze Win32: 2.0.0
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/OpenTK.GLControl.DLL
mscorlib.resources
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_cs_b77a5c561934e089/mscorlib.resources.dll
System.resources
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_cs_b77a5c561934e089/System.resources.dll
DotNetZip
Verze sestavení: 1.10.1.0
Verze Win32: 1.10.1
Základ kódu (CodeBase): file:///C:/Program%20Files/Repetier-Host/DotNetZip.DLL
System.Numerics
Základ kódu (CodeBase): file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
************** Ladění JIT **************
Aby bylo povoleno ladění JIT, musí konfigurační soubor
pro tuto aplikaci nebo počítač (machine.config) mít
v oddílu system.windows.forms nastavenou hodnotu njitDebugging.
Aplikace rovněž musí být kompilována s povoleným
laděním.
Příklad:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Je-li ladění JIT povoleno, budou všechny neošetřené výjimky
odeslány ladicímu programu JIT, který je registrován v počítači,
a nebudou zpracovány tímto dialogovým oknem.
